It is currently Thu Jul 24, 2025 7:36 am
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
PostPosted: Thu Jul 28, 2011 1:23 pm
Mods rock!
kirby wrote:
Anyway Im at work but have some time to grab the bolts while on lunch, But I dont have the sizes with me.
Does anyone know the sizes of
The upper bump stop bolts, Two screw type. 1/4" UNF NUTS - the bump stop has studs on it
The castor rod bolts Sub-frame end are 1/2" UNF NUTS (I'd suggest 'Conelocks') the Lower Arm end is 5/6" UNF x 1 1/4" Long + Nut + Spring Washer
The lower control arm bolts The inner lower arm pins have a 'stud' already on them. Need a 3/8" UNF Nyloc Nut for these
I assume these are all ny-lock?
Any help would be appreciated, It will save me a trip across town.
Sizes embeded in RED
PostPosted: Thu Jul 28, 2011 2:05 pm
Just to add onto the previous post, put the 5/16 UNF tie rod bolts in from the top.
I used nylocs on mine instead of the spring washer.
Try and match the shank length to the width of the tie bar forks too.
