It is currently Mon Aug 18, 2025 7:21 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 265, 266, 267, 268, 269, 270, 271 ... 568  Next
PostPosted: Wed Aug 17, 2011 7:00 pm
Wingman wrote:
Hey Morris, one was and one wasn't, i know what I will be putting back in, and it won't be a split pin lol
Like I said, an R-clip can catch the edge of the hole and it knocks the clip out and then the clevis pin falls out and you have no brakes. It has happened a few times to people on this forum.
I have no problem removing a split pin. What is the trouble? Give it a squirt, bend the ears and pull it out. Where is the drama?
It is better than crashing a car with no brakes.
First I've heard of this - how common is it? - thought the thing to do was use an R clip
David L
PostPosted: Wed Aug 17, 2011 7:13 pm
I've read posts on here before where R clips have come out with disastrous results. I use split pins, but don't bend them out all the way like some folks do.
PostPosted: Wed Aug 17, 2011 10:28 pm
Milatsmadmini
Oil change, plug change, washed air filter socks and re-oiled... thats about it :)
Still need to do a simple wheel alignment and a few other things before saturday...
PostPosted: Wed Aug 17, 2011 10:34 pm
today i tinted my windows (first time for everything), did some more wiring on my dash befor it goes in and started on fixing the ignition and changing it to push button start :). still looking forward to that first drive!
Regards Kermit (TadPole)
PostPosted: Wed Aug 17, 2011 10:47 pm
Pulled the box off
rebuilt the diff
Pulled some bearings out of the box, decided it was shagged and tossed it
Found another box
stuck diff into that
new pots
ready to go onto the top half and into the moke!
You're so square
Baby I don't care
PostPosted: Wed Aug 17, 2011 11:10 pm
adamstuart wrote:
Pulled the box off
rebuilt the diff
Found another box
new pots
Stood around, watched, and occasionally held something steady while Adam did the above. I left the workshop dirty, so it's kosher.
PostPosted: Wed Aug 17, 2011 11:24 pm
Wingman wrote:
Just removed the pedal box, which would have been easy except someone used a split pin for one of the pedal pins, it took me 3 hours to get out, arggghhh lol.
Should have used an R clip. They catch the edge of the hole and fall out on their own which saves a lot of trouble. :mrgreen:
A split pin is the correct thing to use.
Nothing wrong with an R clip, just use a suitably sized one with a washer and you will have no trouble.
PostPosted: Thu Aug 18, 2011 3:37 am
Went to post office and collected a ported 12g940 head that i purchased from ebay, then proceeded to strip head to inspect condition.
Very happy with result. :D
82 BJ42 just completed resto
64 850 Modified(about to start rebuild)
PostPosted: Thu Aug 18, 2011 11:30 am
I gave the Mini its annual grease job ready for the Rylstone run, and successfully swapped out the worn drivers side door latch for a much better one. 8)
[edit] `twas the latch I did, not the `lock' :lol:
[edit 2]
I pumped the hydro a little higher, now ~3 fingers at front. Man this is easier than playing with those damned HiLos... 8)
Last edited by drmini in aust on Fri Aug 19, 2011 1:34 pm, edited 2 times in total.
PostPosted: Thu Aug 18, 2011 3:44 pm
Will keep that in mind, also what do you think about using a cable tie to lock the open side down? Good idea or just stupid?
PostPosted: Thu Aug 18, 2011 8:03 pm
Welllllll, for the first time in over 10 years today, i saw ALL of my lights WORKING :shock: :D :D !! Every single freaking one of 'em :lol: ! The Husband and friends spent most of the day braining over the wiring mess that was under there, and got the whole lot sorted!! Was pretty exciting stuff :lol:!! (only drama being the wiper motor----it might be a dud me thinks :( !).
Really hoping to get her started tomorrow :D :D :D !!!
Cheers, Kim :-)
**purple '68 deluxe!**
***FINALLY wearing number plates----yeaaaaaah baby! ***
Oil Change, Plug Change, Replaced tie-rod ends, checked everything over. Just gotta wash it and its ready for the Rylestone run on the weekend, happy days :)
PostPosted: Sat Aug 20, 2011 3:56 pm
Gave him a bath...
Connected the concealed / powered aerial...
we have tunes! 8)
1970 Cooper'd K
by "Cooper Works"
PostPosted: Sat Aug 20, 2011 5:03 pm
Started replacing front discs, probably won't finish today
PostPosted: Sat Aug 20, 2011 5:55 pm
Bought 4 XLD Classic 5 litres for $9.99 each :wink:
Cooper S Mk2
Cooper S Mk1
Users browsing this forum: No registered users and 307 guests
