It is currently Mon Aug 18, 2025 10:09 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 266, 267, 268, 269, 270, 271, 272 ... 568  Next
PostPosted: Sat Aug 20, 2011 7:16 pm
Fitted Headlining, Sound proofing, front carpets, under bonnet sound proofing,
Tommorrow, fit back carpet, back seats and rear trim!
And load it onto the trailer!
PostPosted: Sat Aug 20, 2011 7:35 pm
any pics ??? :wink:
Pretty Please :D
Dusk Blue
1964 850
PostPosted: Sat Aug 20, 2011 8:13 pm
Broke some pipe going into the inlet manifold, Attempted to change the exhaust and extractors but failed.
Attached new gasket, Lost some bolts in the process then proceeded to tighten it up.
Tested the exhaust and its leaking quite a bit.
So looks like i have to remove the gasket, Fit a new one and put some gasket maker on it.
I hate fuel injected mini's. I want a carb mini :/
PostPosted: Sat Aug 20, 2011 9:32 pm
any pics ??? :wink:
Pretty Please :D
+1 on this also
PostPosted: Sun Aug 21, 2011 3:18 pm
Not exactly my Mini but made a start on an order for 5 voltage regulators built into the original cans. First was an improved prototype, second perfected the prototype started the third and thought if I drill a 1mm hole..... now where the bleeding fine drill bits....after an hour looking gave up and will leave it till tomoroow when I can get to Tandy :evil:
David L
PostPosted: Sun Aug 21, 2011 3:34 pm
Add a cutoff to the battery terminal. Took the kids around the block in it.
Hopefully no more flat batteries when I do the once a month run.
Cheers.
PostPosted: Sun Aug 21, 2011 3:52 pm
Posted: Thu Aug 18, 2011 8:03 pm
kimini wrote:
.........Really hoping to get her started tomorrow :D :D :D !!!
.............and we did! :D :D :D
For the first time since somewhere in 1999-2000, i finally heard my car start!!! Was winding over really strong, then finally started. Have a fuel feed issue, but only cause we haven't really looked that far into it yet :lol: ! Hubby and CO. , spent 2 days replacing my front brakes and sorting wiring (this was the point where my 'independant woman building a car thing', took a step aside :lol: ! but i did still learn alot :wink: ) and hoping to get the rear brakes all done in the next couple of weeks.
:D :D So am pretty chuffed at the moment! :D :D
Cheers, Kim :-)
**purple '68 deluxe!**
***FINALLY wearing number plates----yeaaaaaah baby! ***
PostPosted: Sun Aug 21, 2011 6:04 pm
This space for rent
Wombat wrote:
... when I can get to Tandy :evil:
They still exist!? I haven't seen a Tandy store since the '90s :shock:
PostPosted: Sun Aug 21, 2011 6:22 pm
:oops: :oops: meant Jacar :? or rather the pretend Jacar - local franchise outlet
David L
PostPosted: Sun Aug 21, 2011 6:27 pm
Tandy do still exist; there's one just down from my work. They're pretty well tied up with Dick Smith's now.
But if you're after bits to actually make stuff, Jaycar are far better. Dick's isn't what it used to be in that regard.
PostPosted: Sun Aug 21, 2011 6:29 pm
Did finish the new discs, new rack boots and spark plugs. Crikey the number one plugs a bugger on these!
PostPosted: Sun Aug 21, 2011 8:01 pm
replaced engine stedi bushes re connected all the wiring to the front of my car put a chrome tappa cover on retimed my my car attempted to fix my stupid wiper motor but failed need a new one and i fixed a few scratches
PostPosted: Sun Aug 21, 2011 8:10 pm
Was going to take the fuel tank out of the moke to sort out an in-tank pump but saw a big patch of green and a little patch of brown under the engine bay and decided that she isn't going to the muster if she can't stop weeing on the floor. Put the cover over her and walked away. Water pump is another thing to replace when the engine comes out for the new clutch and rear main seal.
PostPosted: Sun Aug 21, 2011 10:45 pm
tore down an engine loom ran wires where they should go instaled a 8 pin conector plug (narva) ran indiviuual green wires from a 10 blade fuse box (narva) to their designated switches, if some thing blows il know what to change, tomorrow driving light, lo beam and hi beam relays :(
1969 Blue Mini K, 1330cc, Weber 45, polished aluminum roll cage, Race seats, 4 point harness, full rewire incorporating 8 fuses, 6 relays and new headlights :) just needs tyres front shocks and a windscreen til re-register
PostPosted: Sun Aug 21, 2011 11:21 pm
Made the easy engine lifting bracket from the how-to section - looks the part. But since I don't have a welder, I just drilled a hole and used a shackle for the lifting loop.
Then proceded to bash at the pin that attaches the gearchange rod to the gearbox. I'm still working on that one...
Users browsing this forum: drmini in aust and 100 guests
