It is currently Sat Jun 28, 2025 10:15 pm
Post new topic Reply to topic  [ 223 posts ]  Go to page Previous  1 ... 11, 12, 13, 14, 15
PostPosted: Wed Aug 24, 2011 1:23 pm
The elder head is the only one going out on a limb. But theres some good preliminary results.
There has been over 200 hp twinkys made with turbos, and getting very good results naturally aspirated, and a few pierce heads are running now.
Simplify and add lightness
PostPosted: Wed Aug 24, 2011 2:02 pm
Not saying your wrong,
Would just like you to post your DATA...
PostPosted: Sat Sep 03, 2011 6:24 pm
for those who have had these running....have you had any issues with fuel flow or tuning?
put mine on and had a mechanic mate do a quick tune, they ran fine and now have decided to stop working, engine turns over but dosnt fire up, its booked in for a 'professional' tune on wednesday...
any ideas?
PostPosted: Sat Sep 03, 2011 6:37 pm
Ours runs fine just with the standard mechanical fuel pump. Currently playing with the carb setup but it still runs and has been drivable since fitting the carbs.
Have you flooded the engine and the plugs are too wet to fire? Or you could take the tops of the carbs and see if there is fuel in the float chambers.
PostPosted: Sat Sep 03, 2011 6:48 pm
took 2 plugs out and seemed alright, might attempt the others tomorrow dont think its flooded, but then again brother decided to check when i was at work, but it didnt seem flooded today
think il have a break from it tonight n have another crack in the morning
thanks
PostPosted: Sat Nov 05, 2011 11:50 am
So has anyone bolted this one standard out of the box-ish yet?
Onto a standard motor?
Might sound silly, but has anyone stuck one these onto a small bore?
You're so square
Baby I don't care
PostPosted: Sat Nov 05, 2011 12:03 pm
+1 also interested in this
PostPosted: Sun Nov 20, 2011 12:57 pm
Would it defeat the purpose of the exercise fitting a big SU carb to supply fuel and air to all inlets? Im just thinking you could have a compact inlet manifold with an SU out to the left hand side and tubro charged.
The SU would simply be in leiu of a fuel injected throttle body set up.
PostPosted: Sun Nov 20, 2011 1:52 pm
You could do that, it would be the same principal as having a bmw head with a plenum chamber fed by turbo through a carb/throttle body injector.
I don't know enough about all that to tell you if you would be going backwards (if you just used it without a turbo) but it would work.
PostPosted: Sun Nov 20, 2011 2:54 pm
yeah we have run some of our Twinkydonks with single SU on a plenum , worked a treat-->
http://www.youtube.com/watch?v=TPA3_tDbnVk
i still laugh every time i hear myself laugh in that vid :-)
like an evil zombie in a kombie :-)
PostPosted: Sun Nov 20, 2011 5:03 pm
It will fit under a Clubman without any body mods but not a round nose. I have had one running for a couple of months now and good bang for your bucks. Check to head and make sure it is flat, mine was not. If you have a Clubman the throttle linkage is no good because you cant close the bonnet. Keep in mind that to change plugs you will have to remove the Webers unless you have a special plug spanner that you can not buy. You will have to rejet the Webers as they will not run right as they are. :shock:
PostPosted: Tue Jan 03, 2012 10:25 pm
I've taken a pair of valves out to have a closer look at the head. The inside radius between the horizontal portion of the port and the pocket immediately behind the valve is very very tight and needs smoothing on moth valves. On the exhaust it is an even depth in the pocket but on the inlet it is a varying edge. I can take more pics if anyone's interested.
In line with older 12G940 standard (middle) and a late 80's MG Metro 12G940 as well.
I reckon the plug pocket is too sharp on the edges and the pluc tip actually lives way down in there so maybe it's worth opening it up a lot? The chamber volume may get too big then??
And the valves that came with it are the far right of these pics:
Exhaust
Inlet
PostPosted: Fri Jan 20, 2012 8:32 pm
Might not be a problem with torquing down the head after all.
http://www.minimania.com/web/threadid/1 ... thread.cfm
I reckon done in several stages it should be fine.
