It is currently Sat Aug 23, 2025 1:18 am
Post new topic Reply to topic  [ 88 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Thu Aug 18, 2011 3:36 pm
kirby wrote:
If you haven't sorted a spin on filter yet, Ive been gearing up to make some filter mounts that fit a Z9 and mount to the standard mounting points and oil pathways.
The benefit is the Z9 has the relief valve in the filter, is cheaper (as its used on just about every falcon) and most importantly to me at least there are much higher quality performance ones available if you so desire.
Interested. :D
PostPosted: Sun Aug 21, 2011 1:43 pm
Hey Rod how's it coming along mate?
I'll be back home in a week-n-a-half and I'm lookin forward to goin on a bit of a cruise with you in the minis!
The pressure's on..... :wink: :wink:
Rod.
______________________________
'63 Morris 850 (Old Secondhand CAR)
PostPosted: Sun Aug 21, 2011 9:18 pm
+1 :D
Love to do one of those Ballarat to Geelong cruises again.
2008 Prado GXL
PostPosted: Mon Aug 22, 2011 12:36 pm
Interested. :D
My father has done that on both of his Austin A40's (pre BMC ones, so not the a series engined A40 Farina's).
Is there enough room for them in a Mini when mounted in the normal spot?
PostPosted: Mon Aug 22, 2011 4:45 pm
[quote="Rodney"]Well.......here we are......back to this thread........FINALLY ready to rebuild my engine and get Ribena back on the road.
Rodney, suggest you take a photo to post here to ask the guys about the engine stand mount points. Hopefully getting the new hole drilled in the plate tonight.
PostPosted: Wed Aug 31, 2011 11:30 am
Yep.......sorry Bob.......our computer has been having the hic-cups and causing some stress. Anyway, back to it.
Ok folks, I intend on taking up MiniBob's kind offer the use of his engine stand. Just want to check what holes I should use to bolt the block to the engine stand.
I think.....three points........1) the oil pressure relief valve hole, 2) the alternator bracket hole/s and 3) one of the two holes for the oil filter.
I am taking the block to another engineer too.......the one that did all of the work for me forgot to remove the two plugs and clean out the oil gallery that runs the length of the engine, then put in new ones.
Rod Image
PostPosted: Wed Aug 31, 2011 11:40 am
Here's the engine.......
So, I think that by getting some new hi-tensile bolts into the three holes I've mentioned above, will be fine.
Your thoughts please :)
Rod Image
PostPosted: Wed Aug 31, 2011 12:20 pm
Hi Rod, had the slot added to the plate as per our measurements taken the other day.
PostPosted: Wed Aug 31, 2011 12:52 pm
You're a star Bob.
Internet now working on the computer but wireless is yet to be sorted out :(
Work this afternoon/evening........not happy jan :(
Rod Image
PostPosted: Wed Aug 31, 2011 12:56 pm
Mine bolts to both alternator bracket holes and one oil filter hole. That's plenty, no more needed.
PostPosted: Wed Aug 31, 2011 12:57 pm
Cheers Kev....thanks
Rod Image
PostPosted: Wed Aug 31, 2011 1:09 pm
Interested. :D
Any idea on price, I am interested also
PostPosted: Wed Aug 31, 2011 1:34 pm
Doc. So just to make sure please, in Rod's pic above, will be using both holes where the stud is shown and one of the holes just above left (looking at the 'photo landscape).
PostPosted: Wed Aug 31, 2011 3:40 pm
The bolt/stud is in one of the oil filter holes, I use that one.
And I use the 2 bossed holes 1/2 way along the block (turn pic clockwise 90°) these are for the generator or alternator bracket.
it doesn't really matter, as long as you use 3 bolts... :wink:
PostPosted: Wed Aug 31, 2011 4:52 pm
Thanks Doc, appreciate the advice.
Users browsing this forum: No registered users and 214 guests
