It is currently Tue Aug 19, 2025 12:58 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 269, 270, 271, 272, 273, 274, 275 ... 568  Next
PostPosted: Sat Aug 27, 2011 7:50 pm
finally stuck my wheel arch carpets in... managed to do a pretty good job of smearing gel grip all over the accelorator rubber too!
PostPosted: Sun Aug 28, 2011 10:34 pm
Lots of pics...Slowly getting the car ready for paint and reinstall the motor:
[img][img]http://i17.photobucket.com/albums/b99/CPOCSM/DSC01019.jpg[/img][/img]
[img][img]http://i17.photobucket.com/albums/b99/CPOCSM/DSC01018.jpg[/img][/img]
[img][img]http://i17.photobucket.com/albums/b99/CPOCSM/DSC01017.jpg[/img][/img]
[img][img]http://i17.photobucket.com/albums/b99/CPOCSM/DSC01016.jpg[/img][/img]
[img][img]http://i17.photobucket.com/albums/b99/CPOCSM/DSC01015.jpg[/img][/img]
[img][img]http://i17.photobucket.com/albums/b99/CPOCSM/DSC01014.jpg[/img][/img]
[img][img]http://i17.photobucket.com/albums/b99/CPOCSM/DSC01013.jpg[/img][/img]
[img][img]http://i17.photobucket.com/albums/b99/CPOCSM/DSC01012.jpg[/img][/img]
[img][img]http://i17.photobucket.com/albums/b99/CPOCSM/DSC01011.jpg[/img][/img]
[img][img]http://i17.photobucket.com/albums/b99/CPOCSM/DSC01010.jpg[/img][/img]
[img][img]http://i17.photobucket.com/albums/b99/CPOCSM/DSC01009.jpg[/img][/img]
[img][img]http://i17.photobucket.com/albums/b99/CPOCSM/DSC01008.jpg[/img][/img]
[img][img]http://i17.photobucket.com/albums/b99/CPOCSM/DSC01006.jpg[/img][/img]
[img][img]http://i17.photobucket.com/albums/b99/CPOCSM/DSC01005.jpg[/img][/img]
[img][img]http://i17.photobucket.com/albums/b99/CPOCSM/DSC01004.jpg[/img][/img]
[img][img]http://i17.photobucket.com/albums/b99/CPOCSM/DSC01002.jpg[/img][/img]
More to come now it is warming up in the cavern that is my garage :D
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Tue Aug 30, 2011 9:54 am
Picked up my new braided brake hoses and rear brake lines I had made up by the local brake shop.
Great job! Very happy.
The brake lines are in stainless pipe as the guy thought I needed the bling to match the braided hoses. :) :)
Fitted the brake lines and hoses onto the rear subframe and played around with the rear wheel bearings again.
Slowly progressing with the rear subframe rebuild.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sat Sep 03, 2011 7:16 pm
loaded mine onto my tilt tray so i move it around.
of to be pulled apart sunday.
PostPosted: Sat Sep 03, 2011 7:38 pm
did something i always swore i'd never do...
used and air tool to do bolts up.. i did make sure they were square by hand first though...
PostPosted: Sat Sep 03, 2011 8:40 pm
Cleaned the car inside and out including the engine bay, checked the oil, radiator, brake fluid levels as well. need to look at some new tires and a new exhaust (according to the uni sound level meter, its 110 db at 4000rpm)
MINE:
1976 Clubby 1100, 266 Kent cam, slightly worked head. (awaiting paint)
1978 1275LS Hi-Ho Silver with a Camtech 619 cam and some strange looking rockers
PostPosted: Sat Sep 03, 2011 8:55 pm
Spent most of the day at the spray shop while the guys went over the paint work and finished fixing up all of the issues
Nice and shiney now
Then brought it home ready for the next phase, assembly
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Sat Sep 03, 2011 9:01 pm
Dropped the front subby out of a moke
Splitting engine tomorrow 8)
You're so square
Baby I don't care
PostPosted: Sun Sep 04, 2011 4:57 pm
Piss farted about with the three guage bracket - got it in place under the dash - took it out to mount the gauges - just about to solder all the pos and neg wires into one run for each to power the lights in them when I realise I'd be stuck if I had to take them out - put that aside and picked up where I left off on the headlight relays - oh thats right I need the bullet connectors - could use those on the gauge lights as well - now I saw those last week .......... an hour later I gave up looking and put the garbage out.
David L
PostPosted: Sun Sep 04, 2011 5:46 pm
Wifey was at work, so I fiddled and stuffed around on the mini all day.... Just wonderful!
PostPosted: Sun Sep 04, 2011 7:57 pm
New seat belts , new bonnet, new stereo ... Music to my ears 8)
DVS K
Toad the Moke
Brutus the Ute
Mean Monster
Purple People Eater
PostPosted: Sun Sep 04, 2011 8:39 pm
I Karchered the 2 hydro frames for the van, then stripped the front one.
And had a couple of beers for fathers day. :P
PostPosted: Sun Sep 04, 2011 8:40 pm
Looked at my nice shiney, painted body shell then went to Eastern Creek to watch some fast minis racing :) :)
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Mon Sep 05, 2011 7:19 pm
repaired the original interior light fitting with a bit of epoxy putty and after shapeing gave it a coat of white paint. fitted an exhaust pipe clamp fitting to the junction between the 3-1 extractors and the RC40 pipe (supplied one didn't fit and I kept forgetting to pick up one till last weekend)
Started digging out under the house to make an area to park (and work on) the Moke currently out in the weather. If you have have some hard ground to dig I can recommend a big SDS hammer drill that can be set to hammer only with a 400mm demolition bit - makes a good jack hammer :mrgreen:
David L
PostPosted: Mon Sep 12, 2011 5:22 pm
Cleaned up the garage yesterday ready for spring and a fresh start on the project.
A few left over bits :lol:
Mini's I grew up with
Slot car couch
Users browsing this forum: No registered users and 355 guests
