It is currently Fri Aug 15, 2025 11:42 pm
PostPosted: Wed Sep 14, 2011 9:01 pm
thanks gaf,
thanks for the pics and the hints on the clock and anti for rich/lean.
so by 'how you've connected the hoses' you mean 'the' hose?
it seems you've got your fuel in and the other two venting?
i'm already in love with the HIF just by holding it, the butterfly spring return built in, the piston lift button, the adjusting screws..
SOOOO looking forward to getting my car set up right.
PostPosted: Wed Sep 14, 2011 9:36 pm
Well you could say three actual.
Fuel In, Over Flow which in that photo is not attached witch is normally just a a hose hanging under the car and also you will notice in front of the carb near the dash pot a small breather which can be connected to the dizzy (Vacuum advance) but best to blank it as I have in the first pic
PostPosted: Thu Sep 15, 2011 6:28 am
My HIF44 has no lifting pin....normal? Oddball? Have to set mixture by the suck it and see method....
PostPosted: Thu Sep 15, 2011 4:31 pm
With some cars it was impossible to get your hand to the lifting pin so they left it off! :D
PostPosted: Thu Sep 15, 2011 5:25 pm
When I fitted a HIF38 to the Moke I connected the fuel line to 8 (the overflow) and wondered why the heck it wouldn't run. :lol:
Not wanting to hijack, but has anyone hooked up a HIF44 to an Auto 1275? I have one so I wouldn't mind giving it a try. I haven't figured out he kickdown lnkage yet though.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Thu Sep 15, 2011 5:36 pm
Hi Gafmo,
don't you have the engine breather hose connected to the top pipe in the carb ? if not i would block it off.. just sucking air from there. Mine runs better with the pipe blocked.
Luis
PostPosted: Thu Sep 15, 2011 7:33 pm
so opening another can o worms...
dashpot oil?
trudge across to the other side of town to spend 22 bucks and a few hours of my time to get the 'right' oil.
or auto trans fluid
or something else?
and then how much?
cheers again
PostPosted: Thu Sep 15, 2011 7:45 pm
Milatsmadmini
auto trans all the way!
a 500ml bottle for like 7 bucks will last you years! :lol:
PostPosted: Thu Sep 15, 2011 8:10 pm
in a former life i had an automatic or three so i'm sure there's already plenty in the shed...
how much in the pot?
Users browsing this forum: Majestic-12 [Bot] and 366 guests
