It is currently Sun Jun 22, 2025 9:56 am
Post new topic Reply to topic  [ 353 posts ]  Go to page Previous  1 ... 18, 19, 20, 21, 22, 23, 24  Next
PostPosted: Thu May 12, 2011 7:29 pm
Hey Tricky the jet setter
Hows the ride going ol'son got some monkey butt yet :lol: :lol:
I've already bought some other wheels to use that will be going on the race car all good
Cheers Hallsey
PostPosted: Fri May 13, 2011 1:30 am
Hey Hallsey,
Yes, monkey butt and then some, probably baboon butt by now.
Im in Florence, Italy.
Rides going well, but it sure is tiring.
Love the car, and good luck with the wheels,
Tricky
PostPosted: Sun Jul 03, 2011 7:40 pm
Quick update
interior is nearly finished but i'm having some wiring gremlins
I only worked on the car this weekend after not touching for about a month(just over it)
Heres a few pics
I put a little toyota badge on the boot for a hint of what lies beneath :D
Also put some POWERFLEX poly engine mounts in to stiffen up the engine movement, seems to have worked well
Cheers Hallsey
PostPosted: Mon Jul 04, 2011 9:04 pm
Love the badge!!!
Let me know how those bushes work out for you Hallsey, I might have to get some of my own.
Tricky
PostPosted: Mon Jul 04, 2011 9:07 pm
I bought a set of those PowerFlex poly mounts for my conversion but ended up giving them to Rob ('arjay' on the forums). I'll be interested to see how he goes with his too. I've heard good reports in regards to reducing engine movement a lot.
-Alan
PostPosted: Tue Jul 05, 2011 9:02 am
I've got a set on my car.... made a massive difference to engine movement!
Definitely recommended. :D
I've had them fitted for almost a year now and there is still very little movement of the engine even under very hard driving (track days) and less than ideal high speed down shifts (sh!t trackday driver :P )
-James.
Toyota 4EFTE Powered Minivan.
PostPosted: Thu Oct 06, 2011 5:28 pm
Bit of an update
Been stuffing around with the wipers (yes had a look a the sticky's)
but could'nt get the wipers to park, so i decided to fit the starlet wiper motor, made up a little conversion bracket thingy(high tech name)
Had to shorten the mini cable and shorten the outer casing between the
passenger side wheel box and the wiper motor.
I should mention i'm using the starlet switch gear on the column and starlet wiring, anyway works a treat 2 speed ,intermitant and PARK
Cheers Hallsey
PostPosted: Thu Oct 06, 2011 5:53 pm
Now that is a bloody great idea. Good work!
PostPosted: Thu Oct 06, 2011 6:08 pm
Love your work!
Good to see you got it sorted. :wink:
-James.
PostPosted: Fri Oct 07, 2011 7:26 am
This cat has gone feral
good on u mate what a top job.... did u make ur subframe urself??
78 CLUBMAN VAN
researching 4efte conversion.
ANY HELP OR INFO WOULD BE APPRECIATED
THANKS GUYS
PostPosted: Fri Oct 07, 2011 10:45 am
Thanks guys glad they are working :D
Hi CL88MN ,yeah made the subframe myself but with collective idea's from all the builds on here
Cheers Hallsey
PostPosted: Fri Oct 07, 2011 12:54 pm
Top engineering effort
Zulu...
1967 mini Cooper S
PostPosted: Tue Oct 11, 2011 10:54 am
Excellent Hallsey...
Send bracket in CAD or Solidworks - thanks!! :D
Cheers Ol' Sock,
Tricky
PostPosted: Tue Oct 11, 2011 11:12 am
was this difficult???
i dont want to keep the mini switches in my conversion thats all,.
78 CLUBMAN VAN
THANKS GUYS
 Post subject: wiring
PostPosted: Tue Oct 18, 2011 6:54 pm
Hi CL88MN
Was'nt to difficult, i just ground the mounting bracket for the switch gear off the starlet column and welded it to the mini column and as i'm using all the toyoyta wiring its just a matter of plugging it in
hope this helps
Cheers Hallsey
PS sorry for the delay in reply been in tassie for a week
Users browsing this forum: Bing [Bot] and 1 guest
