It is currently Wed Jul 23, 2025 1:43 am
 Post subject: Seized brake adjuster
PostPosted: Tue Apr 19, 2005 6:38 pm
Does anyone know of a way to loosen (remove) a seized rear brake shoe adjuster? Mine is well seized and nothing so far has looked like moving it. If there's a 'special technique' for this I'd love to know. :cry:
1971 Clubman GT - Jet Red
1980 Mini 1000 - Bold As Brass
1967 Riley Elf - Red/White
2002 MINI Cooper - BRG/White
2005 MINI Cooper - BRG/White
2022 MINI Cooper SE - BRG/White
PostPosted: Tue Apr 19, 2005 6:43 pm
have you tried to turn it from the inside with a flat head screw driver bit in a drill??
1974 Moke - 998cc
PostPosted: Tue Apr 19, 2005 7:25 pm
because its quite large
you can squirt some WD40 in it overnight
someone recently suggested penetrating oil for these types of things too
Inconspicuously Conspicuous
PostPosted: Tue Apr 19, 2005 8:11 pm
Oxy torch... warm it up- works wonders on rust!
Watch you don't overheat the wheel cylinder though. :wink:
PostPosted: Thu Apr 21, 2005 4:10 am
Thank you for the advice, unfortunately, it wasn't going to shift. In the end, I removed the back plate and used a vice. Should have done this in the first place instead of spending the best part of a day rounding the adjuster off!
PostPosted: Thu Apr 21, 2005 8:31 am
aahhhhh.... 'if only'....... how many times have I been in a similar situation!!!
Glad you got it sorted. :D
