It is currently Mon Jul 21, 2025 9:24 pm
PostPosted: Sat Oct 22, 2011 4:40 pm
Greetings all.
Had a soft pedal and had to pump em a bit.
Cleaned up the Master cylinder, light hone and new rubber kit. Still not great. Will re-bleed em.
I always bleed LR, RR, LF then RF. I was taught to do the furthest point first. Is this the best way?
Alex.
PostPosted: Sat Oct 22, 2011 5:16 pm
Yep - about right - a couple of other tricks to it as well though.
Just unnip the first union after the master cylinder and pump a couple of times to ake sure you have fluid in the lines.
Then slacken off the adjustment in the drum brakes. Bleed the wheel cylinder furtherest from the master cylinder. Passenger rear. Adjust up those brakes and then bleed the drivers side rear. Adjust up those brakes.
Then the passengers front - if drums adjust up those brakes and finally the drivers side front.
Dont pump furiously. The brake fluid is fairly viscous and all you are doing is frothing it up and trapping air bubbles. Long slow pumps and give it a second or two at the bottom and top of each stroke for both the wheel cylinder and the master cylinder to fill with fluid.
Mike
PostPosted: Sat Oct 22, 2011 5:47 pm
Thanks Mike.
Will get back to it after tea. Been hot and sweaty in Adelaide today! Damm glasses fog up under the dash!
Alex.
 Post subject: Talking about brakes.
PostPosted: Sun Oct 23, 2011 4:49 am
Sorry to Hijack your thread. Would any one know the best place to buy silicone brake fluid at a lower price..... Some want over a 100 bucks for a litre.. That is daylight robbery in my books.
"Let us remove your "SHORTS"
PostPosted: Sun Oct 23, 2011 8:05 am
Just a quick note - did you bench bleed the master cylinder before attaching it to the car? The pedal probably won't travel the full length of the cylinder and can leave air in it if you don't.
PostPosted: Sun Oct 23, 2011 9:53 am
PostPosted: Sun Oct 23, 2011 9:55 am
it doesn`t matter what order you bleed brakes
i let them all loose & drip away by themselves (Gravity bleed)
just keep an eye on the reservoir & keep topping it up as necessary
then lock-up all the nipples & job done
PostPosted: Sun Oct 23, 2011 10:12 am
This ^^.
Get the fluid through the MC then gravity bleed, have a beer while you are waiting.. don't forget to keep the MC topped up above 2/3 full though. :wink:
PostPosted: Sun Oct 23, 2011 10:43 am
4 wheel gravity bleed is the GO!
From personal experience.........only thing that worked for me when I refitted the reco'd booster.
Cooper S Mk2
Cooper S Mk1
PostPosted: Sun Oct 23, 2011 10:52 am
will this work on pesky metro calipers?
you guys doing this on stands with wheels off?
using any piping off the nipples to collect the mess?
PostPosted: Sun Oct 23, 2011 11:12 am
Milatsmadmini
Should do
Nope wheels on, just get ya hands onto the nipples.... :P
small hose into bottle
PostPosted: Sun Oct 23, 2011 11:53 am
mattsmadmini wrote:
Should do
oooh getting my hands on 3 nipples each side.... with a newborn in the house, that's surely a dream... :P
PostPosted: Sun Oct 30, 2011 9:46 pm
Just to let ya know.
Mike - I slowed down and bled them "slowly" and in that order.
Now their 101%. Full pedal and pulls up straight. Had to back the h/Brake off as it was dragging.
Didn't try the gravity method, maybe next time. Sounded tricky and I've got the 997 on the rotis over the pit.
Thanks all.
PostPosted: Tue Jan 27, 2015 7:36 pm
This ^^.
Reviving old thread...
Just rebuilt my brake system including the booster. There is no fluid in the system whatsoever. Where do I start? Bench bleed MC's first? Does gravity bleeding work with the booster (under right wheel arch) or do I bleed that last?
PostPosted: Tue Jan 27, 2015 7:52 pm
I put a booster on mine last year, under the dash. It bled up fine with an unattractive assistant using the pedal. Make sure the MC is bench bled first.
I doubt your booster will gravity bleed initially, however once the pipes are full to the brakes there should be no problem.
Users browsing this forum: minimanic, timmy201 and 85 guests
