It is currently Tue Aug 19, 2025 5:58 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 283, 284, 285, 286, 287, 288, 289 ... 568  Next
PostPosted: Wed Nov 02, 2011 6:40 pm
While trying to NOT hit my head on the bonnet catch :lol: i removed all the spark plugs and gave them a wire brush clean, adjusted the idle screw as it was stalling, also just gave it a general check over and cleaned the engine/bay.
Tomorrow ill start cleaning it ready for MINIFEST on sunday.
1977 Leyland Mini Van - Sold
PostPosted: Wed Nov 02, 2011 7:07 pm
Replaced the voltage regulator and also the plastic bush in the remote housing.
Lot's of bits and pieces ordered that will make for a busy Friday evening.
Now to get the wipers & horn working.
PostPosted: Thu Nov 03, 2011 10:30 am
After 2 and a half years in the garage, finally got my Roadworthy certificate.
Can finally get her registered.
PostPosted: Thu Nov 03, 2011 3:45 pm
Took out full comprehensive insurance for $600 a year! That's the cheapest it's ever been for me, even with all the mods declared! :D
PostPosted: Thu Nov 03, 2011 5:35 pm
Chased up my order from John, and hope to have the goodies here and fitted for this weekend... :shock: And Going to fit a timing seal and cover seal.. The bloodly thing dried up while the engine was out of the car
PostPosted: Thu Nov 03, 2011 8:16 pm
Can't wait to post this myself :(
Carpe Diem
1967 Deluxe (Bluey)
PostPosted: Sat Nov 05, 2011 8:12 am
New wipers.
Got the washer bottle motor going again.
Oil & filter change.
& discovered I have NGK D7EA plugs in that I don't seem to own a socket that fit over them.
PostPosted: Sat Nov 05, 2011 12:03 pm
Not tody but a couple of weekends broke my crank when driving around phillip island :evil: :( this is gunna be an interesting rebuild... Poor little 1098 lasted well. It was an ex KG motor and had a few things done to it. Had a very hard life even before we got it. P plater before us told us it had seen close to 8000 rpm. It had seen 8500 rpm once with us because of a jammed acelarator pedal. Been khana'd over the past 3 years and i guess the track day just killed it. Still deciding which way to go when i rebuild it. Start with the other 1100 motor i have here or to rebuild this one.
PostPosted: Sat Nov 05, 2011 2:28 pm
Fitted up my Voltage regulator, and the indictors. Started to remove the timing chain cover, but found I dont have the correct size massive Socket! :twisted: :twisted: :twisted: :twisted:
PostPosted: Sat Nov 05, 2011 4:11 pm
cleaned up the garage :)
PostPosted: Sat Nov 05, 2011 4:39 pm
Tested the handbrake (through galston gorge)
It works.
You're so square
Baby I don't care
PostPosted: Sat Nov 05, 2011 4:50 pm
It works.
I went through the Gorge to Ivan’s today. I noticed some nice fresh rubber on the tight hairpins and though Humm, Adam must have been through recently :lol:
Didn't think I was actually right you hoon :)
WD40'll fix it!
If it don't, use a big hammer!
PostPosted: Sat Nov 05, 2011 5:23 pm
I put the hood back on the moke today.
That suns nasty!!
Image Image
PostPosted: Sat Nov 05, 2011 5:30 pm
Radiator swap
Had a Month off Mini's and Morris brings me back into it
PostPosted: Sat Nov 05, 2011 5:32 pm
Let dirty little people put their paws all over it in the name of a sale but no sale :(
Buy my car people
Master of the Moggie Army & Founder of Awesomestock2010
