It is currently Sat Jul 19, 2025 4:43 pm
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Mon Nov 07, 2011 6:16 pm
So, a week ago a friend has a drive of my car. "Dude, you seriously need to upgrade your brakes!"
Me: "Nah its just low on fluid mate, she'll be right"
safety is always my first concern champ - always.
obviously.
this made me :D
PostPosted: Mon Nov 07, 2011 6:25 pm
ausmini mod
ausmini mod
Glad I could make someone laugh today ;)
PostPosted: Mon Nov 07, 2011 8:50 pm
Check the seal on the top of the reservoir , brake fluid is hydroscopic and if the seal is split and has been for while and you recently drove in the rain you may have to change all the fluid as any moisture in the system will cause corrosion
( I,m probably telling you what you already know but I,ll post it anyway :) )
as for where your fluid is disappearing to IHKFI
PostPosted: Mon Nov 07, 2011 10:02 pm
I've had the feeling of no brakes twice in my life and never ever want to experience it again! get it sorted out for good pronto!
PostPosted: Mon Nov 07, 2011 10:18 pm
sounds like it been leaking for a while if you knew it needed topping up. But atleast you found out while at low speed. check the brake pedal as most of the time it runs down the peddle. Inside the wheels & tyres but other wise its getting in and having a real good look.
You were lucky
PostPosted: Mon Nov 07, 2011 10:19 pm
Check the pipe joints under the clutch cover area for leaks. It could leak there and you wouldn't notice since there's a hair dryer in the way
PostPosted: Tue Nov 08, 2011 8:31 am
ausmini mod
ausmini mod
Sorted. Rear cylinders.
Stops as good as it goes now!!!!!
