dalmeny wrote:
Can you tell me if plumbing a PCV into the alloy cover and running it into only one side of the webber manifold going to cause any problems? Or should I just throw the ole tin lid back on?
Leave the chrome rocker cover , no need to drill holes in it, you bought it to put some bling in the bay no harm in that , the two breathers you need is this one
http://www.minimania.com/web/Item/U%2F1 ... Detail.cfm
and one of these
http://www.minimania.com/web/Item/C-2A265/InvDetail.cfm
they are only a suggestion if you can find two breathers ( flywheel housing and crankcase ) in Oz it would be better , give Mini King a ring John should be able to sort you out with what you need (02) 4648 1233
Some people use small catch cans , some people run them to a filter , some people just use a longer hose to clear the engine , the most important thing in your case with a clean engine bay is to make it look neat and tidy
