JC, 2 problems i can see with that is/are
one- the mini rear subframe won`t allow enough axle swing/travel through the sub-frame member (where the donut & strut used to be) & would need a massive "opening up" (not really so much of a problem in my books tho, but i personally wouldn`t use the mini rear frame anyways if you were going 4x4)
& two- the """coil-overs & wheel off-set package""" will be a problem (just as you suggest) clearancing also won`t be too much of a problem in my book either tho,,, by recessing the shocks further into the inner-arch/tub,,, a little body work wouldn`t hurt anyone.
I think the minitech 4x4 honda kit is a bit of an over-kill in materials & looks quite heavy & complicated to me, but may well be worth the effort bringing one into Aust to see if any engineers will be happy with it for DOT purposes because making your own may be an uphill battle
"""BUT""" i`d only be happy with a 4x4 conversion """IF""" there was """MASSIVE""" power to be utilised
otherwise a super lightweight hillclimb special much like my own , but with the 4x4 & turbo bike engine package is what i`m doing & bugga the DOT crap,,,,keep it for the race track & just use a twin-cam turbo Bimmer in my Monaco fastback for the tow-car
i can see you`re in a few different worlds of thought JC,,, maybe you need to come have a run in my buggy first, before you decide what you want to do
