It is currently Sun Jul 27, 2025 4:57 pm
PostPosted: Thu Nov 17, 2011 6:33 pm
Actually I like my KAD Quikshift. After 20 years it grows on you. IMHO the main benefit is that the lever is longer so you can actually reach it when sitting in an aftermarket seat.
With a steering drop bracket, the knob is about a handwidth from the edge of the steering wheel in 4th - and not much further in any other gear.
Cheers, Ian
PostPosted: Tue Nov 22, 2011 12:18 pm
if you have a magic wand gear stick they drop straight in the remote box,
shave the bush (see below) the then cut the stick to a desired height, tap a thread on it, voila shorter throw stick
because the stick is so long it has a shorter throw to compensate for the length
get the two sticks with the bushes on the bottom stand them up on a flat surface and note the height difference, trim the bottom of the "wand bush" so that the large spheres are the same height
i polished mine while i had it out, alot of sanding
1969 Blue Mini K, 1330cc, Weber 45, polished aluminum roll cage, Race seats, 4 point harness, full rewire incorporating 8 fuses, 6 relays and new headlights :) just needs tyres front shocks and a windscreen til re-register
PostPosted: Tue Nov 22, 2011 12:50 pm
wow ^^^^^ thats really interesting..
I will give that a go on mine and see what difference it makes.
Thanks 8)
Dusk Blue
1964 850
PostPosted: Tue Nov 22, 2011 4:04 pm
the difference of the sticks is only 3 or 4mm
but i did some rough maths on the sticks with a ruler and some butchers paper
after pivoting both sticks on an axis moving the lower ball 1cm and measured the travel of each stick 30cm from the pivot
stock stick travel was 7.6cm
the wandtype was 6.4cm
so at 30cm height above pivot (where the gearknob is) the travel was reduced 1.2cm per 1cm of lower ball travel
i would measure the travel between first and second but my bushes are worn and that travel would differ for all you guys
PostPosted: Tue Nov 22, 2011 6:40 pm
i have a rod change and i have a KAD quickshift, its great, everything feels a lot firmer. There is nothing to complain about. if you have one its a shorter shift, i can't think of any reason why you would want a longer shift distance soooooo therefore they are better. if you were to truly want one you will buy one out of curiosity.
Users browsing this forum: timmy201 and 84 guests
