It is currently Mon Aug 18, 2025 6:51 am
PostPosted: Mon Nov 28, 2011 6:30 pm
bluewhitecoopers1968 wrote:
simon k wrote:
sh*tballs!
did you do anything to cause it, or did it just happen?
Well yeah I suppose too many revs, I noticed an engine vibration on the way home from a club sprint in tamworth.
http://www.youtube.com/tech160s#p/a/u/0/3PVASc6GKqc
:D :D :D
wish we could use the local go-kart track, but they won't let us near it :(
PostPosted: Mon Nov 28, 2011 6:45 pm
Mods rock!
:D :D :D
So, it was worth it then :D
PostPosted: Mon Nov 28, 2011 6:52 pm
Ahh sh!t :twisted:
Sorry to hear that Richard, not good mate....
Hopefully you can get it sorted, let me know if I can help...
Bugga :roll:
Sir Alec! we are not worthy!
PostPosted: Mon Nov 28, 2011 8:29 pm
graham in aus wrote:
Ahh sh!t :twisted:
Bugga :roll:
Its all good Graham... I knew something wasn't right at the practice day we had. At least it's no longer a mystery.
I'll sort it out over summer, do some work on the gearbox and diff as well and should have her back on the road in time for the cooler period.
I might go a little easier on the revs though. :wink:
PostPosted: Thu Jan 12, 2012 12:48 pm
Well I have been busy with christmas and all but now I have pulled the crank out and measured up... It aint good.
Yep the crank is EN40b cooper S but was on 40 thou undersize already and the main bearing surfaces are badly worn. I'm told this is the max regrind possible :cry:
The block has some flairing on the center main journal, so I guess a line bore would be needed to fix this.
Just thought I would post the update in the hope that someone might tell me that its not as bad as I think :wink:
PostPosted: Thu Jan 12, 2012 2:17 pm
Ahhh,,, bad luck Richard,,, i`m often so awesome when i`m right,,, but other times i really do hate it when i`m right :-(
Probly an oil surge issue when you`re fangin it around corners that`s caused it mate
not much time to look at oil guages etc when you`re into it around the bends
do you ever fill it a tad more with oil before a speed event (500ml more)???? because that`s what i do if i`m floggin an engine without a central oil pick-up fitted
PostPosted: Thu Jan 12, 2012 2:31 pm
Yeah it has a central pickup in the sump and I usually make sure it is very full and the oil is changed before every event or long trip.
Just one of those things that happens I suppose.
I will be looking for a good S crank soon though and beef up the bottom end with a centre strap or 4 bolt main, the block will need to be line bored anyway.
Cheers.
PostPosted: Thu Jan 12, 2012 2:58 pm
Give the crank plenty of endfloat- .003" just ain't enough for a hig revving 1275, the crank webs flex and grab the thrust washers, then the centre main overheats. :cry: As I found out. Luckily mine didn't quite spin in the block, as I stopped when the oil pressure started to go south.
I use .006-.007" end float now, GR uses a bit more.
PostPosted: Thu Jan 12, 2012 4:21 pm
poo - that's basically the reason why I run an 1100S motor...
the original S motor is on the shelf, and the 1100S motors can have as many rebuilds, breakages or modifications as I want, without any concern for longevity
PostPosted: Thu Jan 12, 2012 5:14 pm
Do you find the 1100s block to be stronger or is it just so you don't destroy your rare "s" motor?
Users browsing this forum: Bing [Bot] and 328 guests
