It is currently Wed Aug 20, 2025 7:44 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 293, 294, 295, 296, 297, 298, 299 ... 568  Next
PostPosted: Wed Nov 30, 2011 5:41 pm
started to work on my mini tow trailer!!! making it a full floor but then big storm headed my way, and had to pack up
PostPosted: Wed Nov 30, 2011 6:09 pm
Finished rebuilding a 1360 for 1970minik. :P
PostPosted: Wed Nov 30, 2011 10:55 pm
Found out my floor leaks like a seive and had to pull out all the heshen sound deadener (front and back) and front carpet, for everything to hopefully dry
Now i need to to make it so it wont leak again
PostPosted: Thu Dec 01, 2011 5:55 am
Got the car started and running on injection :D
Well it starts and runs for a few seconds and then floods .. its a start very happy
Beanie
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
PostPosted: Thu Dec 01, 2011 3:51 pm
Just a tip , once the hessian is fully dry, spray it with a heavy coat of Scotchgard on BOTH sides , as much as you can , helps to protect the floor and is a fire retardant ( to a degree )
PostPosted: Thu Dec 01, 2011 4:59 pm
Resident Haemorrhoid
I finished assembling and putting the finishing touches to the new motor
tidied up the engine bay
put the last bits on the motor
mtsmini wrote:
Tombo wrote:
PostPosted: Thu Dec 01, 2011 7:14 pm
went to drive home from school, and mini wouldnt start, nothing, just a click, went home got another solonoid, went back to school to try to fix it. checked and cleaned batter terminals pulled ignition out, swapped solonoids over still nothing put old solonoid back on. Rang a mate to ask what it could be. Told me what he thought and how to fix it went back to school to try it, did it and fixed.
Starter motor was stuck on my flywheel, stuck in gear and rocked it, back and forth, came unstuck and then Started no worried.
PostPosted: Fri Dec 02, 2011 8:16 pm
Still bumbling around with the wiring :?
I think I might have accidentally let some of the smoke out :wink:
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sat Dec 03, 2011 5:21 pm
I had a great day in the shed.
Spent my birthday Tradetools vouchers on lots of little tools that will come in handy. One was a sand blaster.
Sand blasted the outside of 3 steering racks in preparation for sending them away for a rebuild. Had a quick look inside the boots and they all look ok to me. Should be good for re-build.
Packed the racks into PVC tubes with one fixed and one screw-on end. Had to cut a slot down the tubes to let the pinion spline poke through. 100mm diameter isn't enough :oops:
Installed my new parts washer. It's a 3/4 width dishwasher a neighbour gave me for nothing. It now lives next to the laundry tub in my shed.
M
PostPosted: Sun Dec 04, 2011 8:55 am
did some more welding on the moke, and today i will do some more welding on the moke..... :lol:
PostPosted: Sun Dec 04, 2011 9:07 am
I must have my Star Trek glasses on , I read that as melding with a bloke :roll:
PostPosted: Sun Dec 04, 2011 10:08 am
i did nothing to my mini today,,, :-(
i just sat here typing crap into my microwave oven & watched the car races on the telly ;-(
damn heart attack gets in the way of working on my race cars ;-(
2nd artery stent gets fitted in 10 days (& counting)
PostPosted: Sun Dec 04, 2011 10:28 am
I should get the "all clear" from my Ortho Surgeon soon so I can start getting stuck into the heavy stuff again. Back surgery was the best thing I ever had done, just want the go ahead to get stuck in to the Mini again.
Dicko
PostPosted: Sun Dec 04, 2011 2:15 pm
struggled to get her going - rough as guts at first and took several goes to tick over - was fine when warmed slightly tho so took my youngest daughter for a spin around the Gong.
Took my eldest daughter and 3 of her mates for a spin last night and they were equally thrilled and shitting themselves to be in such an old small car. Tho then my eldest decided it will be hers when she can go for her license! ha ha ha don't know about that my dear !
PostPosted: Sun Dec 04, 2011 3:50 pm
clovus wrote:
I wasn't there but the missus says they had a different tool to the one from minisport and it all slipped in easily. One man fed the chrome strip into the seal, the other slid the tool along.
Ive tried to get a better description of the tool but she can't really give me a more precise answer other then it wasn't the same. It mightve been exactly the same, but a different colored handle!
Mine is one I got from minispares in the UK. Has a diamond shaped head on it and took me five minutes each strip by myself once I figured out how it works..
Alec
