It is currently Wed Aug 06, 2025 3:32 am
PostPosted: Mon Nov 28, 2011 12:17 pm
Would the owner of this luvly beast (or anyone else) have any close ups of the engine bay ? Specificaly the alternator.
Would be very grateful of any shots 8)
PostPosted: Thu Dec 01, 2011 2:05 pm
Anybody know if the owner is on here ?
Would really like to know a little more about the alternator set up on this car.
PostPosted: Thu Dec 01, 2011 2:23 pm
It's the same as the one on my car, which should be the same as what's on your car. What do you want to know?
:D
PostPosted: Thu Dec 01, 2011 2:36 pm
I suspect Bob is looking for a smaller alternator for his 7 port project..
2008 Prado GXL
PostPosted: Thu Dec 01, 2011 2:37 pm
Ah, well then in that case there is plenty of alternators smaller than the stock late rover one. Check out basically any thread by NG.
:lol:
PostPosted: Thu Dec 01, 2011 2:39 pm
:D
Oh bugger. From the photo's looks like it's mounted between the engine and radiator or is it just my optics again :lol:
PostPosted: Thu Dec 01, 2011 2:48 pm
No free space in there, it's stock.
If you're using an MPI block, you'll be able to make an adapter that allows an alternator to sit lower than stock, say where the AC compressor would be (on the cars that have it).
PostPosted: Thu Dec 01, 2011 3:01 pm
Reckon there is room even with the front mounted rad ?
PostPosted: Thu Dec 01, 2011 3:08 pm
No experience there, but I'd guess it probably won't.
If you leave the front radiator, the alternator will probably have to get turned around so the body is on the other side of the belt.
PostPosted: Thu Dec 01, 2011 3:20 pm
That's what it looks like has been done in that pic of the Ute.
It really looks like it's further to the right than usual. (zoomed in @ 400%) :roll:
PostPosted: Thu Dec 01, 2011 3:25 pm
Does this help clarify?
PostPosted: Thu Dec 01, 2011 3:47 pm
So you have an MPi with a side mounted rad/thermo fan ? didn't realise that.
When I fit the 7 port kit the coil pack gets mounted on top of the clutch so there may be room to move the rad/fan to the left and make room for a repositioned alternator.
PostPosted: Thu Dec 01, 2011 3:51 pm
you want a nippon denso alternator.
the real tiny ones only pump out max 45 amp
but you can get the same type but not re wound totally new internals & worked from the usa.
i was about to order from these guys, cheap price for what it does and really good to deal with but ended up with a ebay special.
http://www.gzmotorsports.com/
http://www.gzmotorsports.com/racing-alternators.html
from memory he said this still charges in the same rev range as a normal alternator and half the size.. i would email him though.
my set up is different again.
PostPosted: Thu Dec 01, 2011 3:55 pm
There is also a Suzuki one which is really tiny and more than enough amps , I,ll do a quick search and see if I can find the thread , tiny as in really tiny weeny tiny it is
PostPosted: Thu Dec 01, 2011 4:08 pm
Thanks Nick and Dean. I have already bookmarked the GZ site and have my eye on their A101. Whatever I get needs to put out about 65A min.
I guess I have to get the head resting in place before I really can see what can go where
See you at the GDO ?
Users browsing this forum: Bing [Bot] and 92 guests
