It is currently Mon Jul 21, 2025 10:12 am
PostPosted: Sat Dec 03, 2011 8:37 pm
The polisher I used when working for Novus was water cooled, so no problems with toughen glass. If you can feel the scratch with your fingernail, its probably too deep to polish out without causing distortion in the glass.
Member VMCI #19
PostPosted: Sat Dec 03, 2011 9:33 pm
I just raced out to try the fingernail test. It feels more like a rough spot so hopefully not too deep. Novus quoted $235 fitted for new 'screens which I didn't think was too bad but I'd like to try polishing it first just to see.
PostPosted: Sat Dec 03, 2011 9:42 pm
I've used 1/2 a bottle of Autoglym glass polish but it's taking forever. :(
My screen was in an 850 before so the marks aren't even aligned with my wipers.
Just a heads up the autoglym glass polish isnt a polish, Its got no abrasives in it what so ever none of the autoglym range you can buy of the shelf does in fact.
Read the fine print, polish is just a name for good cleaner. Its not going to remove even the smallest scratches.
PostPosted: Mon Dec 05, 2011 2:37 pm
If insured, your company may replace windscreen free of charge without loss of NCD.
Shannons do.
PostPosted: Mon Dec 05, 2011 3:57 pm
Shannons do.
Yeah, but this opens another can of worms- many of the new windscreens (from China?) now don't fit, or they have a tint band that's comes nearly 1/2 way down the damned screen.
Hence why I bought a new rubber, then fitted a s/h screen.
PostPosted: Mon Dec 05, 2011 3:59 pm
But if Shannons fits a new screen and stuffs it up it is their problem.
PostPosted: Mon Dec 05, 2011 4:02 pm
Shannons etc only replace your old screen if broken or cracked though... :?
PostPosted: Mon Dec 05, 2011 4:04 pm
PostPosted: Tue Dec 06, 2011 10:27 am
I have used this kit before on an old merc windscreen and got good results within 15 minutes - enough to reduce the visibility of the scratch so that it doesn't stand out as much. I probably could have got it better if I was patient and spent another 1/2 hour gently polishing.
Make sure you wear a mechanics suit or crappy shirt and do the polishing on the lawn though, being water based it doesn't damage anything but the paste goes everywhere!
+ Too many other classics
