It is currently Sun Aug 17, 2025 9:34 am
PostPosted: Sat Dec 03, 2011 8:44 pm
Any ideas what could cause this?
I am running a new 3 gauge cluster and have run a new wire to the -ve of the coil. Works fine till 2500 and then wont go any higher. The motor is definitely revving past 2500, just not the tacho. I noticed this on a previous temporary tacho i had but thought it was a dodgy tacho. Now im stumped.
Im running a bosch gt40t coil if that helps at all
PostPosted: Sat Dec 03, 2011 9:02 pm
I,m no auto sparky but this might help
http://www.theminiforum.co.uk/forums/in ... opic=39286
Whats the car idling at?
PostPosted: Sat Dec 03, 2011 9:08 pm
Its idling around 800
PostPosted: Sun Dec 04, 2011 6:18 am
Mods rock!
Look at your points and / or condensor in the dissy.
PostPosted: Sun Dec 04, 2011 8:39 am
Thanks for the advice. Checking the points is out of my league of expertise unfortunately. I did have them replaced when I got my car registered a month go though. Hadnt had a tacho in the car before that time so dont know if the issue existed beforehand.
Ill keep trying a few things or else have to get my mechanic to have a look next time
PostPosted: Sun Dec 04, 2011 10:10 am
go for a damn good fang on a really rough rally road,,, full of big bumps & jumps & go really really fast so the whole car gets banged & bumped around really hard
that`ll fix it
& you think i`m kidding ???
PostPosted: Mon Dec 05, 2011 9:37 am
Any chance it could be my coil? I have a transformer type GT40 and with my previous tacho the needle was jumping all over the place which I assume means the voltage was all over the place. Can the internal resistor conk out causing the voltage to jump up and down.
Thinking I might buy an oil filled GT40 and see if that helps first.
PostPosted: Mon Dec 05, 2011 10:56 am
You dont have any other cars you can test the tacho in do you?
PostPosted: Mon Dec 05, 2011 11:11 am
Well its been the same issue with 2 different tacho's now so Im confident its not the actual tacho but an issue in my electronics somewhere.
Its an odd issue but Ill try a few things and see where I get
PostPosted: Mon Dec 05, 2011 1:03 pm
If it is an aftermaket gauge...it will have a "4..6..8" switch on the back.
We had one once that had the 4..6..8 switch wired in reverse.
Sounds as though it it registering for a 6 or 8 Cylinder...check the switch .
1974 1150cc Leyland Mini S racer,
1975 No motor Leyland Mini "ute"
1991 IPRA Honda Integra (in the build)
1995 Land Rover Discovery 300Tdi
CAMS Scrutineer
PostPosted: Mon Dec 05, 2011 3:20 pm
Forget looking at anything else for the moment,
This is where the problem will be.
PostPosted: Mon Dec 05, 2011 3:45 pm
OK well I will get my mechanic to have a look next year on its next visit. I wouldnt know what to look for.
Probably worth just spending the money on electronic dizzy conversion anyway
PostPosted: Mon Dec 05, 2011 5:36 pm
Ya accelerator cable is too short :shock:
PostPosted: Mon Dec 05, 2011 5:37 pm
:lol: :lol: :lol:
Users browsing this forum: Bing [Bot] and 370 guests
