It is currently Thu Jul 31, 2025 8:57 am
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Sat Dec 10, 2011 6:04 pm
I was the same as you Simon, i never run a filter on my S for years, but i decided to
fit one after the elec fuel pump, ( inside the subframe ) when we were going to do the
Rylstone run . I thought that if i was ever going to have a fuel problem , this was when
it was going to happen .
PostPosted: Sat Dec 10, 2011 7:59 pm
I run a 45 Dellorto, I use a Purolator glass filter up at the carby.
Be careful running a filter in the suction line before the pump, it wants to be a big one there (bigger than the Ryco) to avoid flow restriction.
On Barney I used an EA Ford one inside the subframe.
PostPosted: Sun Dec 11, 2011 7:05 pm
Tombo wrote:
I have 2, first inline just before the electric pump in the boot, second a right angle last thing before the carby just incase bits of worn fuel pump try to get through.
I don't think a SU electric pump will fit through the main jet, unless you take the pipe fittngs off :lol:
PostPosted: Sun Dec 11, 2011 7:35 pm
Trouble with English Comprehension??? :? :(
1974 1150cc Leyland Mini S racer,
1975 No motor Leyland Mini "ute"
1991 IPRA Honda Integra (in the build)
1995 Land Rover Discovery 300Tdi
CAMS Scrutineer
PostPosted: Sun Dec 11, 2011 8:37 pm
nah, just warped sense of humour
Users browsing this forum: Bing [Bot] and 100 guests
