It is currently Wed Aug 20, 2025 5:25 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 297, 298, 299, 300, 301, 302, 303 ... 568  Next
PostPosted: Fri Dec 23, 2011 4:51 pm
NOS Bonnet closing bits finally arived from ebay
PostPosted: Fri Dec 23, 2011 7:50 pm
Fitted more bits onto the engine after I spent most of the day Christmas shopping :?
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Fri Dec 23, 2011 10:23 pm
Showed Mum and Dad the Cooper S, they were impressed!!
PostPosted: Sat Dec 24, 2011 8:07 pm
Fitted a few more bits...
Fitted the gear lever mechanism, those pins are a pain , espacially when I had to remove the extractors to fit the bolt holding the top gear lever support to the gearbox..
Now to fit the exhaust when i am allowed out from Christmas celebrations and family matters :)
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Sat Dec 24, 2011 8:35 pm
Got the last bits of felt in the passenger door, dropping the quarter glass in the process, chipping one of the door hinges. Tried to bleed the brakes and ran into a little problem. I ' accidentally ' unscrewed a bleed screw too far and it fell out. When I screwed it back in I mustve threaded it as now it won't do up tight and i cant get it out.
PostPosted: Tue Dec 27, 2011 7:50 pm
Got the van running again thanks to help from Trevor. Combination of timing and fuel issues. It runs, but still need to advance the timing abit more which will involve removing the dissy shaft, atm its hitting the flamin starter motor, but is running ok. Hooray! Thanks Trevor, old hands never loose it do they.
PostPosted: Wed Dec 28, 2011 2:41 pm
We had a win. spun the drive and all good. One step closer.
PostPosted: Wed Dec 28, 2011 6:34 pm
Fitted the new fuel pump and the new exhaust system but discovered the bend in the link pipe needs to be changed slightly so now I am looking for an exhaust shop near Hornsby that may be open this week
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Thu Dec 29, 2011 9:55 pm
Retimed the distributor and finally got the engine to run without overheating.
Newly recored (3) radiator is keeping its cool.
Will need to shorten the carb spring to finally bring down the idle to 1,000.
Sounded great.
Now to refit the last universal after pulling the upper balljoint and finally she can come off the ramps.
Will refit the wooden dash now that the car is running well.
Closer to rego at last.
PostPosted: Sat Dec 31, 2011 9:34 am
Fitted new thermostat and housing gasket. It still leaks. :(
'77 Leyland Mini Van
PostPosted: Sat Dec 31, 2011 10:13 am
This space for rent
I use a silicone-based gasket cement (Permatex, I forget which one) here, it's the only place on the car I do. The thermo housings and head faces are getting pitted now after all these years, and don't seal like they used to.
PostPosted: Sat Dec 31, 2011 11:00 am
New thermostat housings are available new and will solve your leak problems
If the are not too bad then I usually file the face flat but if they are corroded around the stud holes then they are due for replacement
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Sat Dec 31, 2011 11:04 am
Went to Supercheap and spent my christmas gift cards. New battery and other bits and pieces
Went home and finished connecting most of the wiring, connected the new battery and woo hoo I have lights, camera , action.......
Next to finish connecting all of the engine bits and drive shafts before I can start the engine in the car for the first time in 5 or 6 years
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Sat Dec 31, 2011 12:57 pm
Bought a new stereo for it after an ordeal with JB being out of stock! Now to install it!
PostPosted: Sat Dec 31, 2011 10:24 pm
Assembled the drivers side drive shaft with pot joint and cv and then discovered I couldnt get the pot joint to fit thru the subframe hole :oops
So after trying to remove the new cv joint and failing I managed the force the cv end thru the subframe after compressing the rubber cone
So one side took 3 hours and the other side took 30 mins :shock:
1969 Cooper "S"
1967 Mini Deluxe
Users browsing this forum: No registered users and 252 guests
