It is currently Wed Aug 20, 2025 5:29 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 298, 299, 300, 301, 302, 303, 304 ... 568  Next
PostPosted: Sun Jan 01, 2012 12:55 pm
More interior joy for me. Its starting to take shape.
This is how it looked in 2010
And this is how it looked in 1996
I think i need a speedo with a black face to put in again.
PostPosted: Sun Jan 01, 2012 3:47 pm
Nothing fantastic but necessary - managed to get the stubby bit of braided fuel hose onto the fuel tank and connect up the fuel sender ( with a stripped thread on the positive terminal :evil: )
Went to the other end of the car and found the next three things I went to work on needed something extra I didn't have :?
David L
PostPosted: Sun Jan 01, 2012 5:59 pm
sorted all the bolts i had plated in 2009, took me a few goes but i think i have id them all
painted the upper and lower arms..
good way to start 2012 :lol:
PostPosted: Sun Jan 01, 2012 6:16 pm
Finished the rewiring. Headlights, blinkers, parking lights and filled the engine with fresh oil and radiator with water and turned the key :)
Discovered the radiator fixing bolts rubbing on the pulley :cry: and thought I may need to remove the radiator :? , but luckily I managed to make some adjustments and got some clearance. Turned over the engine and got oil pressure so now just need to get exhaust fitted and hopefully start the engine :shock:
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun Jan 01, 2012 6:40 pm
Fixed up some rust. More rust to fix up :( I long to drive it!
1978 Leyland Clubman
PostPosted: Sun Jan 01, 2012 7:55 pm
Pulled the steering column out of the moke and replaced the bottom felt bush, now the inner doesn't rock around in the outer.
Pulled the new uk rack out of storage and pulled back one boot. No grease at all on rack gears and the blob on the inner ball joint was not on the bits that slide against each other :roll:
Put gear oil in it and grease on all wearing bits. Much better now. Then I worked out it is a quick rack :cry: Which isn't what I want on the moke (that's what is in there now). I guess I'll just wait for my reconditioned racks from the Doc. Not in a rush though, the motor still needs work.
PostPosted: Sun Jan 01, 2012 8:00 pm
Put my mini 50 badge on.
1977 Leyland Mini Van - Sold
PostPosted: Sun Jan 01, 2012 9:25 pm
I'm starting on them tomorrow, can send you the 1st one alone if you like. :wink:
PostPosted: Sun Jan 01, 2012 9:31 pm
No rush Doc. I have a list of jobs as long as your arm, the motor won't be going back in soon.
PostPosted: Mon Jan 02, 2012 6:24 pm
Started to fit the Zeemax kit
Looking real good so far :)
Update! Almost finished fitting the kit, should be finished in the morning and then need to look for an exhaust shop that is open
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Mon Jan 02, 2012 10:40 pm
Circled everywhere that I have to sand back to panel beat. Compiled a list of everything I need to buy on my day off.
PostPosted: Mon Jan 02, 2012 10:51 pm
Bought a battery for it
David L
PostPosted: Tue Jan 03, 2012 9:19 pm
Finished fitting the body kit and fitted the RC40 exhaust system
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Tue Jan 03, 2012 9:44 pm
More progress on the Moke's motor. Took the clutch housing and pressure plate off but can't find my puller :( The oil that dribbled out of the flywheel housing when I took the wok off told me the source of the slipping clutch issues...
Took the water pump off and was very happy with the lack of corrosion given the years it has spent sitting.
Took the head off to check it over and replace the stem seals. The old stem seals are not brittle but very stiff. They were stiffer than those that I took of an old 1100S head I had in storage which were very similar to those fitted to the Pierce head so those have lasted much better than the Mokes. I'm going to try those viton ones next I'm sick of crappy ones.
Here's a couple of pics of progress:
The marks down the back of the motor show where the exhaust gasket was blowing.
I was happy that there was no significant wear on the rocker shaft but the ends of the push rods look a bit blurgh.
I also did some measurements of racks and played with some heads.
M
PostPosted: Wed Jan 04, 2012 8:53 pm
Fitted the fuel tank, carby and tried to finish the brake lines and bleed the brakes but unfortunately discovered one of the new pipes is about 20mm too short :?
So back to the brake shop tommorrow
1969 Cooper "S"
1967 Mini Deluxe
Users browsing this forum: No registered users and 215 guests
