It is currently Wed Aug 20, 2025 4:23 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 299, 300, 301, 302, 303, 304, 305 ... 568  Next
PostPosted: Wed Jan 04, 2012 10:33 pm
ran it into the ground after coming off a speed bump at 30 km/h
Being an auto the sump is a bit closer to the ground.
I have warped the radiator shroud and eaten about 1.2cm of plastic off each blade... I am not sure what else is wrong.
PostPosted: Thu Jan 05, 2012 8:37 am
Finally fitted my dash that I bought about 6 weeks ago.
A lot of mucking around with the wiring and I have accidentally wired my clock to the ignition instead of battery. Guess I have to take the dash out again.
joy
PostPosted: Thu Jan 05, 2012 10:51 am
Converted a rear hydro subby to fit a van, for Mike Byron.
PostPosted: Thu Jan 05, 2012 4:17 pm
Fitted the last brake line, fitted the fuel lines and connected the cables to the carby and then started the engine in the car for the 1st time :)
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Thu Jan 05, 2012 4:58 pm
Blew the cobwebs off
ook!
69 mini k
PostPosted: Thu Jan 05, 2012 7:46 pm
Tops! :D
Can't wait to see it in the flesh.
PostPosted: Thu Jan 05, 2012 8:43 pm
adjusted the distributer, running nice and strong
PostPosted: Thu Jan 05, 2012 9:22 pm
I had a fuel bowl fill valve start to leak. Its odd as it is only a couple of years old and low in K's.
Changed it out with a 40,000 year old one from a spare carb until I can get a pair of new ones for the twin SUs. If one is bad, the other one might be ready to go out in sympathy as well.....
PostPosted: Thu Jan 05, 2012 9:26 pm
Sure it isn't just a bit of varnish on the needle? When the petrol evaporates it can leave a layer of crap behind.
PostPosted: Thu Jan 05, 2012 9:42 pm
This space for rent
Well there's a coincidence! One of mine did that the other day too. Have yet to pull it off to investigate...
PostPosted: Thu Jan 05, 2012 10:02 pm
The last time it got a tank was in Point Cook...maybe the fuel is nasty around that side of town... :P
I gave it a good clean and tried to refit it. From what I could see there was wear on the taper, but I might be wrong. The fuel was bucketing out... and the best part is it falls directly onto the exhaust!
PostPosted: Thu Jan 05, 2012 10:07 pm
This space for rent
Can't be the fuel, unless my filter isn't :lol:
For all I know, mine could be a fractured hose on that carb -- it started to smell as I got close to home on one of the HOT days recently, and when I pulled into the garage I popped the bonnet and there was fuel everywhere on that side. It's still like that waiting for me :lol:
PostPosted: Thu Jan 05, 2012 10:23 pm
took some pics!!
http://www.ausmini.com/forums/viewtopic ... 986#847986
PostPosted: Fri Jan 06, 2012 12:05 pm
Stripped a 4spd remote synchro gearbox. Good clean before rebuild.
1964 998 Cooper , 1968 Morris 1100
PostPosted: Fri Jan 06, 2012 1:01 pm
About to fit my new shocks and figure out how put put these damn hi-los in..
Users browsing this forum: No registered users and 217 guests
