It is currently Thu Aug 21, 2025 12:27 pm
PostPosted: Wed Jan 04, 2012 9:39 pm
hi ,any secrect on how to bled brakes....do i need to bench bled the master cylinder first as it new?..thanks....81 gt..uk .model.
PostPosted: Wed Jan 04, 2012 10:04 pm
i "pre-prime" all my master cyls before fitting them
& when i bleed --> i release all 4x nipples & let them all drip-bleed (gravity bleed)... have a cuppa while you keep the reservoir topped up ,,, & then when it`s all happy & no more air is coming out, i run around & tighten them all back up again
Job done :-)
 Post subject: Bleeding brakes .
PostPosted: Thu Jan 05, 2012 9:31 am
A Cuppa? I normally empty a cask of Wine!!
"Let us remove your "SHORTS"
PostPosted: Thu Jan 05, 2012 10:34 am
I have no probs bleeding single circuit ones. But when I reconditioned Barney's tandem one a few years ago I could only get around 1/2 a pedal.
I gave up, drove it to B&R Brakes and they power bled the bugger. 8)
PostPosted: Thu Jan 05, 2012 7:27 pm
I've found the same thing over the years too Doc,,,
For those wondering.. a tip I have picked up along the way is, if Matt's method does not work, (yes sometimes it won't come out, unless you get the flow happening to begin with) (only on the tandem ones mind you this happens)
I crack the joints at the safety ball switch valve thingy,, no idea what they call it, bias valve? but anyway, the thing that saves/helps if you loose brakes to a wheel etc..,, which is bolted above the subframe tower.... this is why single master cyclinders have no trouble bleeding blind folded,, they don't have this.. it is located at the rear subframe :P
ANYWAY... yes I crack the joints/ brake lines going from the master cyclinder and into this valve.. get that flow happening tighten it all back up, and your laughing,, go have a few beers, and shall be done :P
Also if you look at the design of the shape of the pipe (the bend) coming out of the single and tandem master cylinders, they are different,, and one is higher than the other from the level of the fluid in the master cylinder..
One put's 2 and 2 together and will realise that crap won't flow up hill, until it gets a flow happening to begin with..
Those who have run outta fuel in a truck on the side of the road before and had to suck on a hose and taste how awesome diesel is, will know exactly what I mean :lol:
wow,, i think this is the most I have typed on here in bloody ages!! think I must have had too much to drink tonight!! :roll:
PostPosted: Thu Jan 05, 2012 8:12 pm
I actually use a pressure-feed when doing bike brakes. The reasoning being air is buoyant and will get pushed up by the fluid pressure from below. On a car-sized object though you do need an assistant to syphon off the excess fluid from the master cylinder while you push the air up from the bottom. A few pumps while still applying upward pressure will soon have any remaining air bubbling out in the master cylinder. Once there's no more air, close off the bleed nipple, top up the master & you're done.
PostPosted: Thu Jan 05, 2012 9:54 pm
I guess I will find out tommorrow when I bleed my new brake system with all new parts
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Fri Jan 06, 2012 11:45 am
thanks for the help ..will try ..all tips
PostPosted: Fri Jan 06, 2012 9:10 pm
I bled my brakes today and started from all new parts, late version yellow tag master cylinder, 4 spot front discs and copoper s rear wheel cylinders with a limiting valve on the rear subframe with no fluid in any cylinders and also not pre bled on the bench.
I filled the master cylinder with fluid, connected a tube to one of the front bleed nipples, which i cracked open and placed the tube into a jar with fluid in the bottom and pumped the brake pedal, after a few pumps i was getting fluid and bubbles thru the tube and then finally clear fluid. I closed the nipple and then repeated at one of the rear cylinders with the same results.
I then went to each wheel and repeated the process.
All good and I had a good hard brake pedal.
1969 Cooper "S"
1967 Mini Deluxe
Users browsing this forum: Bing [Bot] and 358 guests
