It is currently Wed Aug 20, 2025 10:38 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 301, 302, 303, 304, 305, 306, 307 ... 568  Next
PostPosted: Sun Jan 08, 2012 1:58 pm
Put some castors on a pallet
Working on it is soo much easier
PostPosted: Sun Jan 08, 2012 5:09 pm
moved it 2 meters, so I could begin work on mums Honda C90 Scooter she bought in England and rode all over Europe adn brought back to Aust
PostPosted: Sun Jan 08, 2012 6:51 pm
all floors are in, now its time to do a couple of patches.and wait for my wheels to see how wide my guards need to be . also picked out my rego plate. need to be finished by april all going to plan..... :lol:
PostPosted: Sun Jan 08, 2012 7:02 pm
What do you mean by "wider guards"...What are you doing to lil-ute :roll:
We voted for it Melbourne as People Choice :)
PostPosted: Sun Jan 08, 2012 7:10 pm
I think Big Al is having metallurgical relations with a Moke and is trying to fit 15inches under the guard
PostPosted: Sun Jan 08, 2012 8:20 pm
Finally cleaned out the rusty right hand fuel tank and then poured a special tank repai epoxy inside to provide a nice clean coat over the rust. Seems to have done the trick :)
Then I tried to fit the tank but found the PO was out with their measurements for the holding strap :?
So now I am looking for the correct fitting kit, will ring around tommorrow or order online as I need a few other bits and pieces
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun Jan 08, 2012 9:54 pm
Well today I had to rewire the instrument panel connector plug, replaced the pcb, installed an oil pressure gauge and had to replace my speedo cable.. But over the last couple of days I made some new seat frames to install my cobra classics.. And tomorrow hopefully if my new auxiliary ventiris turn up I can rebuild and install my carbi.. And finally drive my mini!!
PostPosted: Mon Jan 09, 2012 7:18 am
Cranked the badass 1360 over on the floor to get oil pressure up (it's been asleep in the corner for the last 18 months whilst the 1412 stroker has had a run).
1360 with its 3.647 diff is going back in the `wasaMatic' this week- another 10+ HP and up to 8000 rpm, yippee! :P
PostPosted: Mon Jan 09, 2012 2:21 pm
Yesterday - Pulled the twin tanks out for further modification - Enlarging the hose linking them to 20mm ID & changing the return-line inlet angle so it's not pointing directly at the inside of the fuel cap! Removed the holed LHS inner CV boot to get replaced.
1.8L Sunshine - Legal, legit & lovinit
PostPosted: Mon Jan 09, 2012 9:44 pm
auxiliary venturis finally turned up, so i was able to put on my ram tubes as well... now all i have to do is make a bracket for the throttle return spring and we will be cruising! Will be heading from Glenrowan to Melbourne with her on Wednesday.
PostPosted: Mon Jan 09, 2012 10:04 pm
Spent all morning grinding the inner and outer arches to fit my new 13x7 rims and one of them still rubs :x
PostPosted: Tue Jan 10, 2012 7:14 am
im not trying i have done it :lol: :lol: :lol:
PostPosted: Tue Jan 10, 2012 2:26 pm
Just got back from Canberra where I just picked up some Moke side panels and a Moke fuel tank. Happy days!
PostPosted: Tue Jan 10, 2012 2:38 pm
crap, I forgot to give you the tank didn't I..
Well if you need a spare! :oops:
You're so square
Baby I don't care
PostPosted: Tue Jan 10, 2012 2:58 pm
adamstuart wrote:
poo poo, I forgot to give you the tank didn't I..
I was hoping to get up to Sydney and grab it but I haven't had a chance. :lol:
