It is currently Tue Aug 19, 2025 3:45 am
 Post subject: underbody paint
PostPosted: Sat Jan 14, 2012 9:20 pm
what's the consensus on what black paint to use underbody?
i'm preferring brush on
should it be a tar based goop or just a hardcore enamel?
cheers.
PostPosted: Sat Jan 14, 2012 9:34 pm
I had trouble with tar based. Good protection but painting over it was difficult as top coat would react and soften tar then when drying around corner areas (concave radius) the paint would lift of the body in those small areas.
* Have noticed some using WURTH SKS (spelling?) - Some reports of certain areas not drying, but it might be what I try next time?
* Have also read some using hard ute tray back type stuff - Have read some reports that its very hard for your top coat (primer, etc) to key (etch) to it.
Glad mines finished anyway, wasnt the most enjoyable part of the project for me, but very satisfying knowing the whole underside of the car is sealed up nice and fresh hopefully for longer then 43 years this time 8)
PS, I seam sealed all the seams before applying, and I found spraying was easier, quicker and gave the original look.
Mini's I grew up with
Slot car couch
PostPosted: Sat Jan 14, 2012 10:56 pm
i used this under my brick
http://www.supercheapauto.com.au/online ... escription
[img][img]http://i1199.photobucket.com/albums/aa473/kooper70/IMG_4057.jpg[/img][/img]
PostPosted: Sat Jan 14, 2012 11:11 pm
Did u guys want the correct stuff? I can find the name out . The stuff they used in the factory. It gives a smooth finish. And easy to paint over.
PostPosted: Sun Jan 15, 2012 8:44 am
well i have to be a little more honest here...
i'm actually looking to do the chassis of my trailer.
my trailer is a chassis with a ute body mounted on it.
I'm changing the body as it's rusting out but the chassis is solid and strong and already at least 30 years old so wanting it to last me another 30 years.
would i be better off using a chassis black or a killrust epoxy enamel?
cheers folks
PostPosted: Sun Jan 15, 2012 8:45 am
cheers folks
PostPosted: Sun Jan 15, 2012 9:05 am
On my '65 Deluxe I used a CAM brand paintable underbody. Get a $20 Shutz underbody gun and run at about 60psi.
Some products you can paint over and some not. The paintable one goes on a matt finish. Put a primer on top before colour.
On the 'Skippy' Moke project I chose a black (non paintable) product from CALAD. Will take probably 2 tins to cover complete underbody. Cost abput $10 a tin.
I can see in the photos I missed a few bits! :(
Dave K.
PostPosted: Sun Jan 15, 2012 9:08 am
Por 15 for the win
frosty
morris minor community forum
http://www.morrisdownunder.com
PostPosted: Sun Jan 15, 2012 1:13 pm
Frosty, are you known as Sir on another british car base aussie forum?
i always though POR15 was for fuel tank insides? does it do good on chassis as well?
cheers.
PostPosted: Sun Jan 15, 2012 1:19 pm
ok i've done some googling and sold on the POR15...
who stocks it in Adelaide?
where do you people get it from... my googling skills coming up short on stockists in oz..
PostPosted: Sun Jan 15, 2012 2:45 pm
See http://por15.com.au/
PostPosted: Sun Jan 15, 2012 2:59 pm
cheers.
That resembles me Sir.... who you be??
Yes a lot of morry's around now with Por 15 as first coat.
frosty
PostPosted: Sun Jan 15, 2012 7:22 pm
cheers.
on the flipside i'm known as 55update... not on there much, but you have answered a load of questions for me over there :D
the good doctor Kev, thanks again.
PostPosted: Sun Jan 15, 2012 7:40 pm
I,ll be using Septone Rust Shield , needs to be sprayed with a body deadner gun
http://www.septone.com.au/detail.asp?it ... page_num=1
PostPosted: Sun Jan 15, 2012 8:26 pm
Similar to miniDave, I like the K&H product called C Guard.
Applies the same, with a proof coat gun, doesnt require you to be an expert to use it, and they offer grey, black and white, in both water based and solvent based.
The solvent based also comes in grey and black aerosol packs.
mooo, I'm a pig!
Users browsing this forum: No registered users and 314 guests
