It is currently Sun Aug 17, 2025 10:27 am
PostPosted: Fri Jan 20, 2012 6:30 pm
yep , looks just like the "normal" wear for these things to me :-)
quickshifts are pretty good to "cover-up" these little problems :-)
& yes Fiji, i can help you out with a Quickshift
PostPosted: Fri Jan 20, 2012 6:33 pm
Hey Matt,
I think I may run into issues of gear-stick length with a quickshift, as this will be going into my Moke?
PostPosted: Fri Jan 20, 2012 6:35 pm
I have also heard of people rebuilding the large ball to close the slot up to what it would have been like when new; and therefore cut down the slack in this area.
Has anyone done this?
And would the weld be as hard as the (hardened???) steel ball itself?
Ie... not like cheese and be buggered again in months////
PostPosted: Fri Jan 20, 2012 6:39 pm
yeah we`ve bent & shortened the sticks for mokes on many occasions, they work good after that
& yes most "arc" welds will make that section of the ball harder, oxy weld is often a bit softer tho,,, just a bit of a pain shaping it back to fit good & polish it back to a hi-sheen. just a bit of elbow grease :-)
PostPosted: Fri Jan 20, 2012 6:41 pm
Online
If you want it hard, IMO you need to build it up with hardfacing electrode then get the slot recut.
Welding it with MIG wire, whether steel or S/S will not give you a very hard deposit.
PostPosted: Fri Jan 20, 2012 6:44 pm
I might pop up and see my mate that has an expansive workshop.
How about TIG?
I will measure up the slot and see if it's suitable to be milled - more accurate than hand cutting :lol:
Elbow grease for sure!
Nearing the final stages of the Moke to get it back on the road after a quick freshen-up, meanwhile summer is rapidly fleeting.
PostPosted: Fri Jan 20, 2012 7:08 pm
Online
YEAH you can TIG it with hardfacing rod.
But for something this thick- I'd just arc weld the bugger with Cobalarc electrode or similar. :wink:
PostPosted: Fri Jan 20, 2012 7:31 pm
yep, me too :-)
Users browsing this forum: drmini in aust and 339 guests
