It is currently Fri Aug 22, 2025 8:25 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 311, 312, 313, 314, 315, 316, 317 ... 568  Next
PostPosted: Tue Feb 21, 2012 7:58 pm
michaelb wrote:
Spent a few hours getting the paper work sorted and finally obtaining the rego.
All set to go now, just need a wheel alignment and tune and to put the supercharger back on. :) :)
Fixed for you!
Congrats by the way, fantastic effort!
PostPosted: Tue Feb 21, 2012 8:05 pm
I keep hearing subliminal messages :? :? :wink:
Something to do with Supercharging :shock:
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Wed Feb 22, 2012 2:57 pm
I took my 29D distributor off to be recurved, and I had a repro Mk1 S 23D distributor sitting aside for another engine....so I swapped them out to see if it worked (which it does). Very good value at a smidge over 100 dollars including electronic points and cap..
PostPosted: Wed Feb 22, 2012 6:44 pm
Today I put another (5th) layer of putty (bog) around the RH taillight/corner panel. Only five or six other dendts new wiring harnes, replace engine, new headling new dash pads etc etc
:lol: :lol: :lol:
oh I don't know why I'm doing it.
PostPosted: Wed Feb 22, 2012 6:59 pm
Not today but the weekend:
Finished my new air compressor stand/weather proof enclosure behind the shed then tested it out by doing some wore wheel on the die grinder action. Cleaned up all the moke's valves and some others I'm storing then had a go at the carbon on the moke's head and an 1100s head I've got. Very quick with the die grinder and glad I had a face shield, it probably spins a bit faster than those little wire wheels are designed for :shock:
I never realised how out of balance a triple cylinder compressor is until it was sitting up on the steel frame with a bit of flexibility!
Worked out that the carby to manifold studs I ordered are too big. The HS2 studs are bigger diameter to the HIF6 ones. Now I need more.
Gave the old dishwasher a workout with some greasy old parts. It takes the oil off but doesn't get through baked-on stuff. I put all my engine fans through a cycle but they still need a good scrub whereas a bunch of head and rocker studs came out spotless.
M
PostPosted: Thu Feb 23, 2012 5:56 pm
Milatsmadmini
Replaced broken head stud with a non broken head stud amd torqued head back down to 42ftlb... ran out of time to do rockers, tomorrow morning sounds good..
Put the battery on charge and wiped him down in anticipation for the weekend :)
PostPosted: Sat Feb 25, 2012 9:08 pm
Fitted the new wheels and tyres that arrived on Wednesday from UK
PostPosted: Sat Feb 25, 2012 9:12 pm
Wheel aligned 2 Minis with a tape measure. Probably still not quite right, but much better than the 10mm and 4mm toe-out they had. :shock:
PostPosted: Sat Feb 25, 2012 10:56 pm
Pictures?
Whatcha get Steve?
Now with 2 extra ports!
PostPosted: Sun Feb 26, 2012 7:27 am
Nothing too exciting. Some Minilifes with A008s, so they fit under the guards a bit better with no flares.
PostPosted: Sun Feb 26, 2012 4:52 pm
went for a run to kinglake with 4 other minis and a moke :D :D :D
65 panel van Sprog
73 panel van Iggy
PostPosted: Sun Feb 26, 2012 5:34 pm
Removed the head from the Clubman so I can have the valve guides replaced cause I think they are shot
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Sun Feb 26, 2012 6:26 pm
Cleaned up my set off hinges and hung the new doors I have got to make sure everything is aligned properly. Still new bushed in hinges to replace later.
Mini's I grew up with
Slot car couch
PostPosted: Sun Feb 26, 2012 6:42 pm
Got it started for the first time in 6 months :D
WD40'll fix it!
If it don't, use a big hammer!
PostPosted: Sun Feb 26, 2012 6:59 pm
Still sounds good! Who did you get them through?
