It is currently Fri Aug 22, 2025 4:33 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 312, 313, 314, 315, 316, 317, 318 ... 568  Next
PostPosted: Sun Feb 26, 2012 7:20 pm
PDJ wrote:
Got it started for the first time in 6 months :D
Ata boy!
what was wrong in the end?
You're so square
Baby I don't care
PostPosted: Sun Feb 26, 2012 7:57 pm
Good stuff.
Don't forget to retighten the head when hot. :wink:
What did I do today? [well... yesterday]-
Modified the Pulsar dizzy I got from convertible mini on Friday. 8)
PostPosted: Sun Feb 26, 2012 8:10 pm
Went for the third drive in the MIni-Matic after replacing the head.
It is still running very hot so I am not sure what to do next.
Dr Mini what are your thoughts about retensioning the head?
I think I will have to go for a new radiator and a 2 blade fan?
But Sugsr is running and seems to be strong.
Just have to sort out the too hot problem.
1967 Mini Deluxe 1275 heaps of modifications
1969 Mini Matic 1100
PostPosted: Sun Feb 26, 2012 8:13 pm
I'd get the radiator reconditioned, and check the ignition timing.
Too much advance or retard can make it run hot.
Standard 16 blade steel fan should be fine- I have one and it cools my 1360 OK with 120+ HP.
Also check the gauge is reading right.
Retighten the head when hot and readjust the rockers.
Is the MiniMatic heater installed and working (not clogged?)
Last edited by drmini in aust on Sun Feb 26, 2012 8:15 pm, edited 1 time in total.
PostPosted: Sun Feb 26, 2012 8:15 pm
Not me but my 9 year old boy got to stall his first mini. Proud moment i hope he never forgets it.
PostPosted: Sun Feb 26, 2012 8:36 pm
I welded up the sill, a few pin holes in the floor and the odd brake line tab thingy of the 850 shell. Then I welded up a few holes in my exhaust manifold. Geez a MIG with gas is SO much better than gasless for these jobs, no chipping away at flux between welds and no included spattery welds. So much easier to fill holes.
Shame I have to give it back next weekend.
Won't be achieving much for the next few weeks. Hernia surgery tomorrow. Ouch.
M
PostPosted: Sun Feb 26, 2012 8:46 pm
adamstuart wrote:
Ata boy!
Its was the Tacho lead, a dodgy fuse and a dumb arse connecting up the new points :lol:
Got to get a plug for the Minispares manifold yet. The oily rag keeps on blowing out.
No exhaust on yet and it'll only run with me on the throttle for a few seconds. I think the timing might be out as it sounds like a top fuel dragster on 2 cylinders so still a bit to do before I'm back on the road. :wink:
WD40'll fix it!
If it don't, use a big hammer!
PostPosted: Sun Feb 26, 2012 8:50 pm
I started and took Morris for a run around the block today. Then Started on Maria and her hanging electrics. I have 3 weeks for reg which also getting her to run again with a unknown HIF44 which has been referbed
PostPosted: Sun Feb 26, 2012 9:24 pm
Oil change and radiator flush for Brutus ...with help from matty :lol:
Tanks matty xx
DVS K
Toad the Moke
Brutus the Ute
Mean Monster
Purple People Eater
PostPosted: Sun Feb 26, 2012 11:30 pm
Milatsmadmini
Tanks matty xx
:D
fixed head stud, forgot that coolant was still in engine/radiator, proceeded to loosen up head studs to replace blah blah.... coolant in bores (bugga!) replaced head stud and adjusted new roller tip rockers.... changed oil (looked like melted chocolate ice cream with that much water in it) Cleaned up spark plugs at Marls place and Sanchez is now a happy little moke once again :)
PostPosted: Tue Feb 28, 2012 8:30 pm
Fixing the small rusty bits around the door hinges of the Clubman
Cut some rust out from the A panel
Pity about the humidity as the fresh metal rusts so quick :(
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Wed Feb 29, 2012 6:19 pm
Helped to sort out the timing of the engine. The Megajolt had an incorrect setting since the Dyno day when we were trying different options and added -5deg to the whole map.
All good now and should have the car home on Saturday
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Wed Feb 29, 2012 7:54 pm
Last few arvos I've been assembling this buggy.
Front and rear sub frames bolt straight on to the middle frame. Just need to find a central tunnel (or make one), make a floor pan, mount the shocks, wheel arches, steering column and pedal box. Then the next step is making the braking system, fuel, battery and wiring.
PostPosted: Thu Mar 01, 2012 1:48 pm
Had my windows tinted with 25% tint..
I need some privacy in the back seat.
$180 for the 2 sides and rear done..
PostPosted: Thu Mar 01, 2012 8:49 pm
Looks good, is that an average sort of price or did you get a good deal? I'd like to get this done to keep the clubby a little cooler :)
Users browsing this forum: No registered users and 234 guests
