It is currently Fri Aug 22, 2025 2:23 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 316, 317, 318, 319, 320, 321, 322 ... 568  Next
PostPosted: Fri Mar 23, 2012 6:44 pm
Made a new clutch seal fitting tool and changed the cheapo seal in the 1412 stroker for a Payen UK one.
Now I know it works OK I can change the comp one in my car next week (which I probably buggered up during fitting- as it has leaked from day 1).
PostPosted: Fri Mar 23, 2012 7:06 pm
Cut a little bit more rust out of the clubbie
I think that all for now
Also picked up a litre of Scarlet Ohara to hopefully paint this weekend if the weather is fine in Sydney
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Fri Mar 23, 2012 7:16 pm
Wash the brick 2wice in 3 days frigging rain.
Clean inside & engine bay .
Adjust hilos took ages one was seized & the donut was turning. adjust brakes fixed rear brake light.
Good times
PostPosted: Fri Mar 23, 2012 8:34 pm
received my 12G295 head!! thanks Miniman!!!
off to the machinists it goes!! gotta get it to breath!
1971 Mini Clubman 1100
1968 Morris Mini Deluxe 998
http://www.facebook.com/geelongminiclub
"Everybody should drive a Mini, everybody should own a Mini at some point, or you are incomplete as a human being." -James May, about the classic Mini.
PostPosted: Sat Mar 24, 2012 5:13 pm
Took off the locked door on the spare shell and disassembled the door hardware. Hopefully will figure out why the door wouldn't unlock tomorrow.
PostPosted: Sat Mar 24, 2012 7:14 pm
DROVE IT, round the block. Its all coming together now, wont be long untill its roadworthy time !!
PostPosted: Sat Mar 24, 2012 7:45 pm
Bodywork
PostPosted: Sat Mar 24, 2012 9:47 pm
installed the "new old stock" passenger door lock button that Doogie gave me, and some other injection stuff ;)
PostPosted: Sat Mar 24, 2012 10:25 pm
Played with motors, heads and carbies for Alice... Think I've found myself a good package now. 1098 +0.40 thou, mini K 4 sync box, 202 head with some decent work done to it :) thanks WEBBY78LS for the help and generosity! Really goes to show how good the local mini community is :) now to decide on the carby??? Just keep the 1 1/12SU or play with a 40mm weber? Hmmmm decisions decisions.
All coming along nicely now :) let's hope 123 grosso doesn't blow it up at hay :wink:
PostPosted: Sat Mar 24, 2012 10:30 pm
:roll:
PostPosted: Sun Mar 25, 2012 7:48 am
Primer/filler on the rust repaired areas of the clubman
Rub down is next and maybe some colour if I don't have too many disruptions today
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Sun Mar 25, 2012 4:17 pm
Fixed the locked door on my spare shell. Turns out the pin holding the handle into the housing was installed backwards. Stoked I found out the problem and now the door works as it should.
PostPosted: Sun Mar 25, 2012 4:20 pm
Drove it to the petrol station. It ran out of petrol halfway there. It reminds me that I really should have a look at that fuel tank sender. Meh - it's full of fuel now, so probably not going to happen :lol:
'77 Leyland Mini Van
PostPosted: Sun Mar 25, 2012 4:23 pm
washed the mini and gave the engine bay a nice de grease.
PostPosted: Sun Mar 25, 2012 5:25 pm
This space for rent
Welded up a nice long crack in my carb heat shield to cure it of an annoying buzz at around 3000rpm. While it was apart, I finally got around to fitting a T-piece to the vacuum ports, rather than having one carb sucking the engine fumes and one blocked off. Checked the mixture with the Colourtune afterwards - what a big difference! One carb took a half turn to lean it off, the other a half turn rich.
Took it for a spin, and vroooom! No annoying buzz and plenty of go!
Users browsing this forum: No registered users and 193 guests
