It is currently Sun Jul 27, 2025 10:43 pm
PostPosted: Tue Mar 27, 2012 5:23 am
Hey all,
I'm looking at fitting an A+ 1275 block/crank to replace a damaged A series block, I'm gonna just fit the remote gearbox, pre-verto clutch and head from A series, which I still have.
Will it swap ok or are there any issues with doing this?
Thanks,
Richard.
PostPosted: Tue Mar 27, 2012 6:37 am
It'll all be fine. :wink:
PostPosted: Tue Mar 27, 2012 11:36 am
Mods rock!
Sometimes the rear No. 3 Main Bearing Cap bolt might just kiss the the Gearbox, not always, but check. Do a trial assembly without gaskets and the half moon seal first.
Your old dissy won't swap straight over. You'll need to change the drive dog and shorten the shaft a whisker, or get an A+ dissy.
PostPosted: Tue Mar 27, 2012 12:18 pm
And as well as what GT said you need to run a different oil dipstick :wink: Silly dipstick me didnt realise that to a saturday night when the motor was put into the moke to be hill climbed the next day :oops: :lol: Josh at mini imports in melbourne will have everything you need. Top bloke :D
PostPosted: Tue Mar 27, 2012 1:52 pm
Mods rock!
Good point. Any UK Dipstick (A or A+) up to about 96 works. The Ozzy made flat ones won't.
PostPosted: Tue Mar 27, 2012 3:19 pm
excuse my ignorance - what's the difference?
PostPosted: Tue Mar 27, 2012 6:06 pm
They go straight into the block, there is no guide tube.
[edit] you can make an early round one fit, but the stop washer isn't in quite the right spot (I can't remember if too high or low).
Last edited by drmini in aust on Tue Mar 27, 2012 6:35 pm, edited 1 time in total.
PostPosted: Tue Mar 27, 2012 6:24 pm
Thanks for the reply's guys, will keep this all in mind.
Cheers, Richard.
Users browsing this forum: Bing [Bot] and 80 guests
