It is currently Sat Jul 19, 2025 4:52 pm
 Post subject: fuel tank help
PostPosted: Sun Apr 01, 2012 10:07 pm
im looking at getting a bigger fuel tank made for my 78 leyland van
does anyone know of someone or lead me in the right direction. Im in Perth but will go almost anywhere.
hope be back on the road soon with a blown 1275.
PostPosted: Sun Apr 01, 2012 10:09 pm
How big do you want to go?
If you fit an LS / Rover tank and a RH tank you'll have 60 litres.
Easy to do and cheaper than getting a tank made.
PostPosted: Sun Apr 01, 2012 10:12 pm
Rover Cooper
Why not look at a rover tank, they hold 35 litres i think, they should be easy to get hold of
PostPosted: Sun Apr 01, 2012 10:17 pm
Van.
PostPosted: Sun Apr 01, 2012 10:19 pm
Dammit, thought it sounded too easy you're right. How'd I miss that?
:lol:
PostPosted: Sun Apr 01, 2012 10:20 pm
i was thinking of getting one made the same as the original but bigger to take advantage of all of the original space, and i will divert the exhaust to give me access to the whole of the rear under section of the car
PostPosted: Sun Apr 01, 2012 10:22 pm
The wife's 77 van is getting a 20L jerry can in the back. I might paint it to match the decor... :lol:
PostPosted: Sun Apr 01, 2012 10:33 pm
Had a Mini many years ago where the fuel tank was fitted within the subframe area. This would work with a van. Not sure how the exhaust was run. The tank was from an old Holden or Morris Minor - not sure which, but it was a good fit. Will try and find an old photo.
PostPosted: Sun Apr 01, 2012 10:39 pm
I have a mate here in town who has done this to his mini van (amongst other mods) i could go and take a photo of it except its out of town at a panel beaters.
He had someone weld them up from aluminium. Sorry i cant go and take photos. but from memory he had to make it an odd shape for the exhaust.
PostPosted: Sun Apr 01, 2012 10:43 pm
its more finding someone who will make it for me due to the legal issues
PostPosted: Sun Apr 01, 2012 10:44 pm
Check out some of the engine conversion threads. I'm sure I've seen a van or two that had tanks from other cars adapted into the back.
PostPosted: Mon Apr 02, 2012 8:57 am
you could try the spridget (sprite/midget) tanks, i think we used to use those to fit inside the rear subframe years ago
PostPosted: Mon Apr 02, 2012 9:49 am
Export mokes have tanks in the rear subby too.
You're so square
Baby I don't care
 Post subject: FUEL TANK VAN
PostPosted: Mon Apr 02, 2012 10:13 am
I had an alloy tank made to fit in the area rear of the battery in a van
You will need a pipe 1/2'' ID from the main tank to the alloy one and a breather fitted to the alloy tank
Mine holds about 25 L, when you fill the main the other tank also fills
Alpine Mountains full of Mini's and Moke's.
