Another way of removing the radiator provided by Matt Read .
The MiniMan wrote:
Removing the Mini Radiator
OK ,,, before this blows out into a frenzy of people stuffing with their radiator shrouds,,, the mini radiator is already an "Easy-out" item if you know how
There’s a simple standard easy way,,,, & then there is the "usual" misinformed , time consuming, head ache, pain in the arse way
Listen (read) & learn
Firstly, you take the 2 engine mount bolts & nuts out from the passengers side,,, then jack the engine up on that side,
2ndly you undo & remove the 2 vertical bolts that mount the bottom radiator bracket to the engine mount bracket (Not the 2 bolts that are located side ways through the lower radiator bracket to the lower radiator cowl, just leave them there),
then with the top radiator bracket & both top & bottom radiator hoses un-clamped, it’s just a matter of lifting the whole assembly, radiator with cowls attached , in one big bit, straight up & out of the hole... easy-peasy
the factory even made the later radiator cowls one piece because there really was never any reason the make it 2 pieces in the first place (except to fool the un-initiated)
It’s that easy,,, the Morris 1100 ones are even easier as they only have one bolt at the bottom.
A weenie bit of patience & a tad of practice & common sense & your radiator will be out in about 5 mins flat... & back in about 8 mins
Not all weekend like some do trying to remove all the cowl screws & removing it separately,,, WRONG!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
sorry but this topic really gets my back up , because it’s so easy & quick doing it the "CORRECT" way
ok,,, rant over, & again sorry but dam!!!!!!!!!!!!!!!!!!!!
no offence to anyone intended, I just mean this post as a help to any & all who listen to ideas of modifying things that just really don’t need modifying.
MadMatt "Ready" Read---> "The MiniMan"
Hope this helps
