It is currently Sun Aug 24, 2025 12:21 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 321, 322, 323, 324, 325, 326, 327 ... 568  Next
PostPosted: Wed Apr 11, 2012 6:47 pm
message
PostPosted: Wed Apr 11, 2012 7:22 pm
Drove the mini for the first time with the Supercharger fitted :lol:
I'm hooked :shock:
Just need to sort out the stupid condensation in the inlet manifold which causes problems in traffic :(
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Fri Apr 13, 2012 8:05 pm
Recieved all the blower bits from Ben in SA....WOOHOO I can finally ge this brick finished!
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Fri Apr 13, 2012 8:09 pm
Hooroo
Don't you just love his workmanship? I got one of his ignition kits and it was oem quality.
M
PostPosted: Fri Apr 13, 2012 8:47 pm
Trying to work out what the bits are. The black button for the blower clutch is just the ducks guts! The welding is superb!!
Rob Forsyth
Miniot!!
PostPosted: Sat Apr 14, 2012 10:48 am
Overhauling an HS6 for a bloke, took the new throttle shaft WZX1178 out of the packet and the damned 1-3/4" butterfly won't fit in it. Slot in it is only 41mm wide.
Either the shaft maker effed up, or its an HS4 one with the wrong label. :cry:
Might have to get the needle files out and put my glasses on...
PostPosted: Sat Apr 14, 2012 11:23 am
broke an engine steady bolt off in the head (drivers side one) :( got the passenger side steady on then found i cant put the coolant hose on because the nut is in the way :( so now waiting for some gaskets to arrive so i can space the thermostat housing up a bit to clear the nut :(:( guess it wont be running again this weekend, oh and found out the passenger side brake hose has a blockage in it so have to get a new one of those too :(
PostPosted: Sat Apr 14, 2012 5:11 pm
Put in the front windscreen and continued on with the woodwork. Also realised that there's no way to reuse the vinyl off the door cards, so have to rethink my plans on that.
PostPosted: Sat Apr 14, 2012 5:24 pm
Home from work and starting to assemble the new walnut dash and getting all the guages in. Radio will wait but want to get the loom back in as well.
Hooroo
Rob Forsyth
Miniot!!
PostPosted: Sat Apr 14, 2012 5:48 pm
Aligned the boot and bonnet so the gaps are much more even. Test drove it to ensure all was well. Flushed the engine and adjusted the thermo fan. Test drove it to ensure all was well. Put on new boot lid straps and realigned the steering wheel. Test drove it again.
PostPosted: Sat Apr 14, 2012 6:04 pm
took it to the university oval and let #1 daughter have some driving practice before motorkhana tomorrow - she hasn't driven it for 18 months...
PostPosted: Sat Apr 14, 2012 6:40 pm
Finished the boot and beaver panel on the 1100
Ready for some filler and some paint now!
Worst part of the car is DONE!
Now onto the bit i'm slow at: Brakes.
You're so square
Baby I don't care
PostPosted: Sat Apr 14, 2012 8:24 pm
Picked up a rotisserie thanks again Marcello, wire wheeled the bondo on my car covering some nice bumps and bruises. Started unbolting the subframes, with any luck she'll be spinning on a horizontal axis tomorrow.
So... I'm Seifer
PostPosted: Sat Apr 14, 2012 8:37 pm
Bought him some "new" front brakes - thanks Harley. The 8.4" discs should offer a bit more bite than the current 7.5s.
Just need to spend the time getting them on now. :)
PostPosted: Sat Apr 14, 2012 10:54 pm
rebuilt the steering rack and put it back on the car,
made and installed a new fuel line 8mm
undersealed the engine bay
took out rear subframe (what a mess)
