It is currently Fri Aug 22, 2025 1:53 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 322, 323, 324, 325, 326, 327, 328 ... 568  Next
PostPosted: Sun Apr 15, 2012 11:48 am
Now housesitting at the same location as the mini, I came home from work after stopping by TheMiniMan and pulled out the rear windscreen and took of the wheels so I can get new tyres and get the rims powdercoated!
1978 Leyland Clubman
PostPosted: Sun Apr 15, 2012 1:07 pm
Didn't actually need it - it needed a jump straight onto the starter motor. But I took 2 1/2 year old Charlie for a drive around the block, the first time the Estate has gone in 12 months. So delighted!
Plus more woodwork.
PostPosted: Sun Apr 15, 2012 1:17 pm
Plus more woodwork.
Good news. Thats a great photo :lol:
PostPosted: Sun Apr 15, 2012 2:05 pm
I took my mate for a spin in the gold coast convention centre carpark. He was gushing about how direct the steering was, how it drifts a bit around the corners etc. I don't think I have converted him yet, as he drives a Audi RS4 but I will keep trying.
Did a huge leery power slide in the rain coming home too! Man, this motor has some grunt in 3rd gear. Big thumbs up to Matt Read for the tune up :lol:
PostPosted: Sun Apr 15, 2012 7:13 pm
Had another play with the engine but way too much condensation on the inlet tube. :(
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon Apr 16, 2012 11:31 am
geeeee.....
I decided to replace the rear window rubber and front window rubber!!! MY HANDS HURT SOOO BAD!!
Found some rust in the process so attacked that and fitted the new seals with a lot of effort...
PostPosted: Mon Apr 16, 2012 1:30 pm
(yesterday)
spent the day motorkhana'ing with #1 daughter, then gathered a few insects on the way home
PostPosted: Mon Apr 16, 2012 9:08 pm
Adjusted the clutch and brakes.
ordered some nice new cooper S discs and a camber kit from minispares.
Lets hope it all gets here without a problem. :lol:
1977 Leyland Mini Van - Sold
PostPosted: Mon Apr 16, 2012 10:05 pm
Helped Scott change the timing chain and other bits on Annie Moke
PostPosted: Tue Apr 17, 2012 2:59 pm
Went to pick n payless to search for some struts. Upon finding a few different types, the best combination was put together and I made up my bonnet strut conversion.
Also went and popped in at GR to see how my motor is coming along. Cant wait for that stroker goodness!
PostPosted: Tue Apr 17, 2012 4:07 pm
Tipped the molasses out of the 1100S block + head (it's been in 2 weeks), hosed it all out and refilled with 1:3 molasses:water mix.
It's coming along well, 90% of the rust is gone but another week won't hurt.
PostPosted: Tue Apr 17, 2012 7:52 pm
Installed some new extractors and attempted to change my steering rack in the rain.. I lost the battle for the steering rack :/
I could not drop the rear of the sub frame to take the rack out.
I might of broken the joints that connect to the steering rack and the wheel :(
does anyone know how to re grease these?
http://www.flickr.com/by_dan
2014 Land Rover Defender 90
PostPosted: Tue Apr 17, 2012 8:05 pm
If you mean the tierod ends, just buy 2 new ones from karcraft, they are cheap.
PostPosted: Tue Apr 17, 2012 8:20 pm
ahh thats what they are called..
Thanks!
I might give the rack another go next month..
Are there any tricks on getting the back of the subframe to droop?
PostPosted: Tue Apr 17, 2012 9:45 pm
Need to undo the top tower bolts, subby to floor mounts, and loosen the front teardrop mounts.
Oh and remove the shock absorbers... and the exhaust pipe..
Read the Haynes manual, you do have one I hope!
It's a Rover auto, so I've probably forgotten stuff.. I've only worked on Oz Minis. :lol:
