It is currently Fri Jul 18, 2025 3:50 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2, 3  Next
 Post subject: Rear Sway Bar
PostPosted: Mon Apr 30, 2012 3:07 pm
Anyone fitted a rear sway bar to a hydro Mini?
Im searching for the 2 locating links as well. Its a Whiteline bar.
Cheers.
Haydn
PostPosted: Mon Apr 30, 2012 3:14 pm
I have a Kmac bar from the 70's which fits under the scews which hold the bumps stops onto the top of the swing arms.
On a seperate question, I am interested in fitting a front and rear sway bar to my latest project and am interested to know whats available? I guess I will need to look to the UK as I cant imagine any Aussie ones still available?
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon Apr 30, 2012 7:14 pm
K-Mac still make them
I just fitted a front and rear bar to my mini - custom made locally by Signature Sway Bars by Don Selby of Selby Suspension fame and his Son - reasonable pricing too. Around ~$270ea fitted. I had mine custom made to go under my dump pipe and subframe for the 4EFTE.
I'm sure they could supply the links.
Made a massive difference to body roll.
Located in South Nowra.
Signature Swaybars
Shock Absorbers, Springs & Suspensions - Nowra South, NSW
Unit 10/34 Quinns La, Nowra South NSW 2541, Australia
(02) 4421 2722
PostPosted: Mon Apr 30, 2012 7:49 pm
Thanks for the replies and sorry for hijacking the thread :)
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Mon Apr 30, 2012 7:51 pm
Is there need for a sway bar on a hydro car? I'm sure there are some members that could answer that??
PostPosted: Mon Apr 30, 2012 7:55 pm
I've had one on mine for years
I guess I'm used to it and have now come to expect minimal body roll with a bit of oversteer :)
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Mon Apr 30, 2012 8:01 pm
I get by quite well with comp hydro bumpstops on the rear, and a set of shocks on the front.
These bumpstops (Aeon springs) increase the spring rate on the outer rear wheel when cornering, much as a roll bar does.
PostPosted: Tue May 01, 2012 9:25 am
er... well... um.... thanks for the replies.
Not really after advice on whether it works or not. Just the asking about procuring the locating links.
Has anyone actually fitted a Whiteline rear swaybar to the rear a Hydro Mini?
Ive got an agent for Whiteline chasing it up but i thought i might not be Robinson Cursoe......
If and when i get it on, I'll let you know if it works or not.
Cheers.
Haydn
PostPosted: Tue May 01, 2012 10:31 am
Hi Haydn, My Cooper S is hydro with a KMAC rear sway bar. If I remember I will take some photos tonight and show you the connection point onto the top of the rear swing arm.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Tue May 01, 2012 12:44 pm
Where does it mount to the rear arms, Haydn?
PostPosted: Tue May 01, 2012 1:27 pm
that's the part he's looking for...
I believe they go to the spring lugs
edit: maybe not, this one looks like it goes on the brake backing plate bolts
PostPosted: Tue May 01, 2012 2:24 pm
Woo! Lots of pictures there Simon...
Poeee, Im pretty sure it locates on the helper spring mount. I just need the 2 bits (links) that come off there and then go into the hole on each end of the bar.
I had one on my old yellow moke but it was dry suss of course, but it did work a treat. Really made the front bite under load.
I'll keep searching.
Cheers.
H
PostPosted: Tue May 01, 2012 2:30 pm
Oh, and thanks Michael.
Id be rapt seeing how yours locates.
cheers.
Haydn
PostPosted: Tue May 01, 2012 3:12 pm
Call the guys i posted above - they designed the whiteline swaybar (whiteline brought all the jigs of them when they first started) - they will be able to sell you the linkage and post it to you and they are cheap.
Whiteline has passed through a few hands now and are more interested in the modern jap stuff - also most of their production has gone to China.
