It is currently Fri Aug 22, 2025 8:42 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 326, 327, 328, 329, 330, 331, 332 ... 568  Next
PostPosted: Mon Apr 30, 2012 9:13 pm
SteveOB wrote:
started looking for a replacement head for my Matic and preparing myself for another Mini mechanics bill !!
There is nothing special about a 998 Matic's head, it's just a 12A1456 (same as a 998 Deluxe really).
It's the rare Morris 1100 automatic (1098) that got the 12G295 Cooper head.
I have a couple of very good CAM4004 late 998 Clubby heads (same size valves as yours), PM me if you want one. Cheap.
PostPosted: Mon Apr 30, 2012 9:36 pm
PM sent
ta muchly !
PostPosted: Thu May 03, 2012 8:50 pm
Chrome trim moulding added for seam underneath doors.
Successfully swapped the park location in the wiper motor thanks to Dr Mini.
Gave it a quick clean for the big day tomorrow.
Fingers Crossed!
PostPosted: Thu May 03, 2012 8:56 pm
Fitted the LED lights along with the resistors to the mini caring trailer, so the BMW doesn't complain all the time!
PostPosted: Sat May 05, 2012 10:13 am
fitted proper air filters and some suspension goodies!
PostPosted: Sat May 05, 2012 4:26 pm
Wheeled in out into the sun, looked at it for a while. Pushed it back into the garage. Need that engine back!
PostPosted: Sat May 05, 2012 5:25 pm
Tried to fit the new bushes and pins to my door hinges. The old bushes were shot! New bushes went in fine, but now the pins won't fit through. Looks like I should've opened up the hole in the hinge slightly before pushing the bush through. Any suggestions other than getting another set of bushes and putting them in after drilling out the holes a bit more?
Cheers, Matt
Don't be fooled, Gruhms is not my real name.
PostPosted: Sat May 05, 2012 5:32 pm
Hi Matt
Don't drill out the hinges as you need the bush to be tight
I have had a few issues and wasted a couple of pin kits along the way
Couple of tips, make sure the pin is pressed in square as if off centre then it will destroy the bush and also press the bush in with the slightly tapered end first
Then once the pin looks like it is lined up and straight then bring out the BFH
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sat May 05, 2012 5:46 pm
Thanks Michael.
The problem is, the pin won't go through at all, and if it does, I can't see it moving freely in the bush. As I tried to put it through, it was just pushing the bush out. I've destroyed one bush so far, so I'm going to need to replace it at least.
Cheers, Matt
PostPosted: Sat May 05, 2012 7:46 pm
Hi Matt
If you were closer to Gordon I could come and do it for you
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Sat May 05, 2012 7:51 pm
Mini Deluxe is home for a service. Replaced the front brake wheel cylinders, checked the rear but they were good, replaced the rubbers in the brake master cylinder then bled the brakes, all good
Checked and adjusted the points, cleaned the carby fuel bowl.
Washed and started to polish and should finish tomorrow
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Sat May 05, 2012 9:06 pm
Put him up on stands so I could start mucking about with the new brakes I bought a few weeks ago. Any tips for undoing the big-arse hub nut? 'Cos nothing much is going to happen if I can't get the old hubs off.
Also, any tips on where to get a pair of Y-pieces to split the single hose into a double to plumb into the dual ports on the four-pot calipers?
(I'll whack a pic up tomorrow to clarify, if that's any help.)
PostPosted: Sat May 05, 2012 9:24 pm
Made up a temprary dash panel to house a couple of gauges, tune-ometer and some speakers. Will be getting replaced eventually so it isn't to flash but definately better then the bare hole.
My '78 Leyland Mini on flickr
PostPosted: Sat May 05, 2012 9:46 pm
Stripped out and cleaned up a Deluxe front subby to go in the 1412 stroker powered hydro van.. :P
Now for some prep and black paint!
PostPosted: Sun May 06, 2012 7:32 pm
Finished buffing the deluxe, fitted an alarm system, fixed up a few rusty spots in the gutters, repaired a small rust spot in the rear of the bonnet. Looks like a few more evenings work until finished and ready to release back into Sydney traffic
1969 Cooper "S"
1967 Mini Deluxe
Users browsing this forum: No registered users and 298 guests
