It is currently Sat Aug 23, 2025 1:00 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 328, 329, 330, 331, 332, 333, 334 ... 568  Next
PostPosted: Sat May 12, 2012 8:16 pm
Put it on TDC and measure the stroke.
76.2mm = a 998
83.7mm = a 1098.
PostPosted: Sat May 12, 2012 9:28 pm
Oilstoned my block and head, put new head gasket on. Fiddled with the dissy and the solenoid, Made sure the torque setting on everything and i mean EVERYTHING where right then gave them a bit more for good measure :wink: Motor ready to go in tommorow. Still deciding if i should send my right hand tank off to get profesionaly treated or just buy the POR15 kit and do it myself.
Opinions?
PostPosted: Sat May 12, 2012 11:15 pm
So you made everything right, then made it wrong?
You're so square
Baby I don't care
PostPosted: Sun May 13, 2012 12:50 am
Finally got the radiator back in.
Will put the coolant etc in tomorrow.
Next job off to Matty R for some carby work. Woohoo.
Alec
PostPosted: Sun May 13, 2012 9:55 am
Carter,
Better test your torque wrench, many of the clicky shiny ones are hopelessly out. By 10/ft/lb or more. :lol:
PostPosted: Sun May 13, 2012 11:56 am
Put my machines up on stands.. it will be six months before they bark to life again..
PostPosted: Sun May 13, 2012 12:24 pm
There's always room in my carport Mick
I can take them for a two weekly burn
You're so square
Baby I don't care
PostPosted: Sun May 13, 2012 12:27 pm
Carter,
Trust me doc this one is good. Its my grandfathers old warren and brown torque wrench. Had a few hundred spent on it a few years back getting it all recalibrated to make sure it was right :D
Adam, i like to have piece of mind that everything is tight especially how last time it was done wrong and things where to loose...
There's no room in your carport! I've seen it!
What I really need is someone to do burnouts, collect a numerous speeding tickets through intersections on two wheels. Are you up for it?
PostPosted: Sun May 13, 2012 4:09 pm
CARTER_GT wrote:
Carter,
Yeah that wrench is good, I have one too.
Tighter is NOT better. If you exceed the elastic limit of the bolt or stud, it's toasted. :roll:
They list torque settings for a reason... :wink:
[edit] What did I do today? Drilled out a pair of hydro top arms to take shock bolts. They are going in the hydro van.
Geez they are tough stuff, I'm glad I didn't have to drill by hand!
Last edited by drmini in aust on Sun May 13, 2012 4:52 pm, edited 1 time in total.
PostPosted: Sun May 13, 2012 4:21 pm
Took the fuel tank out of the Moke today. It is a custom one but when I made it I used the level sender out of the donor car as it is attached to the EFI pump bracket. Trouble is the resistance doesn't match the guage so it never reads right. I thought at the time I would be able to overcome the issue but electrickery and me don't see eye to eye.
I'm going to modify a mini unit and install it.
While the tank is out I'm going to re-plumb the hoses so I can mount the Facet in the rear subframe instead of the engine bay.
M
PostPosted: Sun May 13, 2012 5:20 pm
bought a router, machined some ram tubes into my inlet runners and polished the inside and then welded up the air box which means ive almost finished making the bottom section of my inlet manifold for the suzuki engine, ran out of argon for the tig :x only a few more weekends and il have the manifold finished :roll:
PostPosted: Sun May 13, 2012 6:02 pm
Went for a drive down MonaVale road and back :twisted:
Luv the Supercharger
Just need to sort out the fuel build up when stopped at the lights, at the moment I find a couple of blips of the throttle before I take off seems to burn off the excess fuel and prevents the engine from bogging down .
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun May 13, 2012 10:13 pm
Milatsmadmini
i know i am!
and ive got a new covered home for a car with near exact mini dimensions....
more than happy to help a brother out ;)
PostPosted: Sun May 13, 2012 10:22 pm
It didn't even have the moke in it when you saw it!
Put the moke sideways with the clubby along the wall
1100 against the other wall and your cooper S keeping the oil slick warm
I can see it now
You're so square
Baby I don't care
Users browsing this forum: No registered users and 281 guests
