It is currently Sat Aug 23, 2025 4:47 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 333, 334, 335, 336, 337, 338, 339 ... 568  Next
PostPosted: Mon Jun 04, 2012 6:16 pm
Started a bit later today so gave the roof a polish.
PostPosted: Mon Jun 04, 2012 7:38 pm
lookin great, can you post a photo of the whole car? i was looking at that color scheme as one of my choices.
1971 Mini Clubman 1100
1968 Morris Mini Deluxe 998
http://www.facebook.com/geelongminiclub
"Everybody should drive a Mini, everybody should own a Mini at some point, or you are incomplete as a human being." -James May, about the classic Mini.
PostPosted: Mon Jun 04, 2012 8:10 pm
Removed the rear brake drums and then the wheel cylinders on the Cooper S as they have started to corrode :( :(
Have to order some new .625 cylinders tomorrow.
One of the problems of only using the car 2 or 3 times a year...
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon Jun 04, 2012 10:23 pm
Went outside to find some knob had given the side mirror a massive whack so when I tried to adjust it the whole thing just fell apart, had to patch the lot together with elastoplast from my training bag so I could drive to training!
No excuse not to fit the new pair of mirrors I bought months ago now....
Basil - 1978 Leyland Mini, Brooklands Green, bit of a bitsa, and a park brick in the boot. :)
PostPosted: Tue Jun 05, 2012 5:28 pm
Installed my velour headlining and front windscreen.
Carpe Diem
1967 Deluxe (Bluey)
PostPosted: Tue Jun 05, 2012 5:57 pm
Purchased some new rear brake cylinders for my Cooper S, probably try and fit tonight
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Tue Jun 05, 2012 6:18 pm
Replaced the bottom radiator hose and took it for a preliminary test drive.
'77 Leyland Mini Van
PostPosted: Wed Jun 06, 2012 11:21 am
Gradually getting bits back together, last two nights i managed the following:
1) hooked up the rods to the gearbox, what a pain this was. Should have been a easy job but, the bush thing connecting the stabiliser rod to the engine/diff end was cactus and it was impossible to get the outer metal bit out while in the car, so i bodged it up until i get a new one and have the engine out of the car again (will be before i drive/register it).
2) Bolted most of the bits back on the engine, generator/starter/carbie etc..
3) Went to connect accel cable, but couldn’t find it anywhere, spent an 45min searching but couldn’t find it, must have been cactus and chucked it, hmm now need to buy another.
Next steps left before i can kick it in the guts for the first time in years:
1) New accel cable
2) New fuel
3) New oil
4) Charge battery and put back in
5) Connect cables from battery
Questions
1)Where should the cable from the floor starter button through to the starter? (under, around, through subframe?)
2) Anything i should do prior to starting a engine not started for ages?
PostPosted: Thu Jun 07, 2012 3:13 pm
Kurross wrote:
3) New oil
Questions
Yes, put the oil in!! :lol:
Turn motor over with spark plugs out until oil pressure present!
:P
Sir Alec! we are not worthy!
PostPosted: Fri Jun 08, 2012 7:55 pm
Stripped right side suspension. Bought all new adjustable geometry/ bumpstops and shocks all round.
Took out my steering rack (some F**Kwit had welded the new floors over the subframe bolts) so took me an extra 2 hours to get it out.
Picked up my new Drmini steering rack.
Started dissasembling right side hub.
PostPosted: Fri Jun 08, 2012 8:06 pm
Last night I finished putting the new rear brake cylinders in the Cooper S and bled the brakes. Now it's all ready for a "test drive" tomorrow... :wink:
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Fri Jun 08, 2012 8:29 pm
Replaced the old Lucas coil with a Bosch unit. No more stalling coming back to idle and so much smoother at speed. :lol:
My '78 Leyland Mini on flickr
PostPosted: Fri Jun 08, 2012 8:50 pm
Removing paint
PostPosted: Fri Jun 08, 2012 9:17 pm
Replacing clutch arm, clutch seal, and other clutch stuff........... Well actually Ken at MiniAutomotive is... lol :P
PostPosted: Sat Jun 09, 2012 7:41 pm
new leads, new plugs and a bit of start ya bastard and i drove it (out of the shed) for the first time since September 2007.
and with the oil warmed up, he got an oil change and a filter.
:P 8) 8) 8)
Users browsing this forum: ClubmanGT and 258 guests
