Beanie wrote:
so nobody has driven an alfa ( i know dirty word ) with factory webers ?
as said before properly tuned they dont fart cough ... but if they are jetted wrong
Beanie
I've tuned Alfas (I was into Alfas and Fiat twincams) and you are right, BUT that doesn't apply with 1x 45 Weber with BIG chokes (for HP) on a 5 port 1275-1400cc A series though. Totally different kettle of fish.
Leave Alfa's std air correctors & emulsion tubes in, and your A series won't hardly run.
Your Alfas have ony 32mm chokes is a 40 carb (usually) and their cylinders are way bigger. So yeah, you can nail em off the line- where's the top end though.
If you are going to choke a 45 Weber down so far it runs nice down low on a road Mini you may as well fit an SU or 2, and get MORE HP.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
