It is currently Sun Aug 03, 2025 5:15 am
PostPosted: Sat Jun 30, 2012 6:53 pm
I wonder if she really was Ginger?
I think the Skipper would have been chasing Mrs Howell.
PostPosted: Tue Jul 03, 2012 8:52 pm
https://www.swiftune.com/Checkout/Shopp ... r%20basket!
ATB Differential for Classic Mini
Early 14K ATB differential
What is the main difference between these two Quafie LSD's?
From what I read the Early one needs some sort of mods to the crown wheel and maybe some other bits and pieces...is this correct?
PostPosted: Tue Jul 03, 2012 9:00 pm
Kennomini wrote:
https://www.swiftune.com/Checkout/ShoppingCart.aspx?Type=success&Messages=Product%20was%20successfully%20added%20to%20your%20basket!
your link is dodgy
reading about the 14K, it sounds like it uses a non-standard type crownwheel. My mate has one like that
the other one is what you want, dropped straight in to my remote 'box
PostPosted: Tue Jul 03, 2012 9:16 pm
The link is from the swiftune website.
PostPosted: Tue Jul 03, 2012 9:31 pm
I can see that, I can also see that it's a success message after adding a product to a shopping basket. But since I don't have a shopping basket, and as such there aren't any items in it, it's kinda useless
PostPosted: Tue Jul 03, 2012 10:01 pm
the link works when I click it but anyway;
this should be a link to the latest model LSD
http://www.swiftune.com/Product/381/atb ... -mini.aspx
and this should be the 14K early LSD
http://www.swiftune.com/Product/1104/ea ... ntial.aspx
PostPosted: Tue Jul 03, 2012 10:36 pm
the site remembers your IP address and stores what you've put in your cart, the link you put up was intended for your IP address and when the server noticed yours and simons didn't match it wouldn't display the page correctly.. just giving some form of broken link message or the like.
So what's the last thing you remember...
I'm pretty sure you were..
WRONG ANSWER!!!
PostPosted: Fri Jul 13, 2012 4:58 pm
If anyone is interested in prices they are selling them for 550 pound or around $840 to $900 depending on current exchange rates.
PostPosted: Sun Jul 15, 2012 5:55 pm
MED also sell them for the same price incase you didn't realise. Just another option if you are looking at buying some other bits. I have purchased parts from both MED and Swiftune and found them to be very good in regards to service and prompt delivery.
PostPosted: Sun Jul 15, 2012 9:45 pm
The "early" ones use LSD CrownWheels - which have a much bigger diameter hole in centre of the crownwheel. And yes - require LSD output shafts, circlips etc ($$)
Diff housing may require some machining
eg http://www.swiftune.com/Product/639/swiftune-crown-wheel-and-pinion-47.aspx
* and not all LSD Crownwheels fit (eg MiniSpares are a slightly different diameter by a few mm - Jack Knight ones do fit OK. It would probably be possible and easier to machine a few mill from the Quaiffe rather than the Crownwheel - but I just got a different crownwheel. )
The newer style just uses a standard crownwheel and "Pot joint" outputs.
eg http://www.swiftune.com/Product/418/swiftune-crown-wheel-and-pinion-45.aspx
Functionally I believe they are otherwise identical....
