It is currently Sat Aug 23, 2025 7:06 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 343, 344, 345, 346, 347, 348, 349 ... 568  Next
PostPosted: Sun Jul 15, 2012 4:40 pm
Cut up clubman number 406 with 123 grosso it's gone to mini heaven now. Now to cut the 61 or 62 850 up so I can make room for the new project/s :) couldn't be happier!
PostPosted: Sun Jul 15, 2012 4:47 pm
Used a metal brush on a drill and sanded same as yesterday and 4 days now still going never doing this again lol :oops:
PostPosted: Mon Jul 16, 2012 12:12 am
Paint
PostPosted: Mon Jul 16, 2012 3:42 pm
Finally got around to making an adjusting bracket for the alternator to tighten the belt. :)
1.8L Sunshine - Legal, legit & lovinit
PostPosted: Tue Jul 17, 2012 6:03 pm
Changed my rear right wheel bearing, No more squeaky sound.
I also installed my rear camber brackets.
http://www.flickr.com/by_dan
2014 Land Rover Defender 90
PostPosted: Thu Jul 19, 2012 9:48 am
My Minispares order has been shipped.
I had 44 individual part numbers to pick and pack and every single one was in stock. Love that.
That's order #2 of probably 3 total for the 850 body and Moke refresh. I think there will be 1 maybe or two more to go for the 850's 1100S power unit depending on what I decide to do with it.
I'm keeping them just under the $1000 threshold.
M
PostPosted: Thu Jul 19, 2012 4:47 pm
Milatsmadmini
Re-registered the moke!!! wooo!!!! :lol:
PostPosted: Thu Jul 19, 2012 7:39 pm
Fitted the Washer pump and hoses.......
And washed it..
PostPosted: Thu Jul 19, 2012 7:43 pm
And washed it..
How many times did you have to refill the washer bottle to do the whole car?
Basil - 1978 Leyland Mini, Brooklands Green, bit of a bitsa, and a park brick in the boot. :)
PostPosted: Thu Jul 19, 2012 7:52 pm
ha ha ha
PostPosted: Thu Jul 19, 2012 9:33 pm
Fitted the lightened & balanced flywheel and orange dot clutch to Laingy's 1377 stroker motor.
PostPosted: Fri Jul 20, 2012 9:59 am
It’s alive!! :D :D :D
(I gave up on the pulsar dizzy, couldn’t get spark, so bought another and replaced the module, still no good, tried bench testing, nothing)
So threw in the ole points one and amazingly she started the very first press of the button!! Very surprising, because it hasn’t been kicked over for years.
Now I need to try tune it up, I even splashed out on a timing light yesterday (not that i have ever used one before or know how), so i’ll do some searching on here to work it out, shouldn’t be too hard.
PostPosted: Fri Jul 20, 2012 1:17 pm
Hi Kevin,
Is lightening and balancing a task you always complete for your new projects? I am tempted just to get my motor going back together but am trying to be patient and plan to lighten the flywheel and then get the harmonic balancer, crank and flywheel dynamically balanced.
For a general road car which I hope to have enough power to be punchy when I needed but cruise along nicely also is this something that is recommended :?
Mini's I grew up with
Slot car couch
PostPosted: Fri Jul 20, 2012 1:24 pm
thought about my minis :roll:
Beanie
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
PostPosted: Fri Jul 20, 2012 1:48 pm
Ordered a whole lot of small parts for the clubman.
Just warming up my credit card for John Schmidt's sale tomorrow
You're so square
Baby I don't care
