It is currently Fri Jul 18, 2025 3:32 pm
 Post subject: tuning an su
PostPosted: Fri Aug 10, 2012 6:41 pm
ok boffins
i'll admit im rather clueless when it comes to the carby's, has anyone got any info, "how to's" or advice on what to do?
i'm running twin 1.25's, the car seems to be idling high at the moment , but unsure whether the idles are even, mixtures are balanced (i think)
i have gunsons colour tune and carbalancer kits, not really sure how to use them correctly but
please help!!!!!!!!!!
im looking at you doc haha
PostPosted: Fri Aug 10, 2012 8:02 pm
the Scientific Publications #64 workshop manual has what I reckon is the best explanation of how to synchronise twins properly
I have a carbalancer, but the most useful bit of it is the rubber tube - poke it into your intakes and listen
PostPosted: Fri Aug 10, 2012 8:15 pm
ok thanks simon
how can i get hold of it but??
PostPosted: Fri Aug 10, 2012 8:46 pm
this one is my favourite, but it's usually cheaper than this - http://www.ebay.com.au/itm/1959-1971-sp ... 35bc77eee3
this is meant to be excellent, but I don't have a copy - http://www.ebay.com.au/itm/MINI-FACTORY ... 1e70cdba45
both of them cover Australian specific stuff, so they're a must-have
PostPosted: Fri Aug 10, 2012 10:35 pm
i have the 2nd one but not the first one
PostPosted: Sat Aug 11, 2012 8:03 am
Underground, overground, wombling free
Don’t know if this going to help……but worth a look to help get an idea.
Don’t know if it’s been posted before…….
http://www.youtube.com/watch?v=ASeMfXfj ... _embedded#!
Cheers neil
I have a mini because I'm not allowed to play with small thermo nuclear weapons any more. (bloody neighbours you’d think they would be happy that they don’t have to turn a light on when they need to take a leak in the middle of the night)
PostPosted: Sat Aug 11, 2012 9:37 am
I agree ^^
That SP #64 manual was also sold as a Gregory's #64.
I reckon it's the best manual for Oz roundies. Wiring diagrams are correct, and it has correct details on Oz windup doors, unlike most others.
PostPosted: Sat Aug 11, 2012 9:44 am
Two emails sent with manuals attached.
Edit: sorry second one is 9Mb hope it gets through
Edit: Both bounced
I'll put them up in a cloud link - hold on while I sort it :wink:
David L
PostPosted: Sat Aug 11, 2012 10:56 am
Here is a link to the files in Drop Box https://www.dropbox.com/sh/lnz1w1vgds5ho2e/DJSEMs2PNw
The JPG files are from SU Butec - the other is a PDF files of a manual - parts are not clear - sorry
David L
PostPosted: Sat Aug 11, 2012 5:39 pm
read the section on adjusting twin carbs
PostPosted: Sun Aug 12, 2012 3:32 pm
just finished tuning my carbs
ok so standing at the front of the car facing the engine the right hand carb was about 3/4 to a full turn behind the left carb on idle adjustment, about 3 full turns of mixture nut behind left carb (ie had to be 3 times richer, and idle higher)
question is, is that normal??
car is driving 10 times better, idle is lower (it was revving that high at idle that it was getting hard to get into gear) , take off and power through the rev range is ridiculous compared to what it was (no more surging lol), feels like a new car lol
cheers for all your help guys
PostPosted: Sun Aug 12, 2012 3:49 pm
The difference in the jet height nut position may be explained by wear in one jet or on one needle.
If they are fixed needles (most HS2s are) the jet need to be centred so it don't rub on the needle when the piston is down.
If the carbs have done a lot of work, fitting new jets & needles to both is a good idea.
PostPosted: Sun Aug 12, 2012 4:00 pm
they may need re centering, but they havent done much work, they are virtually new, put on the car in december, brand new from england
but when i raised the piston thing they both fell freely
i think thats how you check??
PostPosted: Sun Aug 12, 2012 4:06 pm
Yes, they must fall freely to hit the bridge, and not stick.
PostPosted: Sun Aug 12, 2012 5:36 pm
yeah both fell freely, no sticking anywhere
i dont know, might have something to do with the engine, i have no idea whats been done to it/in it
