It is currently Wed Jun 25, 2025 1:52 am
PostPosted: Mon Aug 20, 2012 9:09 am
Who can tell me whether the distributor on a B18C7 is the same as on a B18C6?
Trying to source a cap and rotor button but nobody lists the parts for a B18C7 and they are NLA from Honda :roll:
PostPosted: Mon Aug 20, 2012 1:22 pm
The info I got was that the 6 vs 7 are just to ID the areas for distribution, as some areas get better specs.
Like you, I was also unable to get any decent info on the distributor cap & just had to order it from Honda & hope it was correct. I'm not an expert, in case you wondered, but if you can send/request a photo from where you are ordering the distrib. you may be lucky. :?
A surprisingly large number of B-series parts are interchangeable tho. :)
1.8L Sunshine - Legal, legit & lovinit
PostPosted: Mon Aug 20, 2012 1:30 pm
I think I've found the correct genuine items from the US after a bit of looking. It is listed as suiting the B18C5 but looks identical... hopefully I can match up the part numbers to make sure :wink:
When I rang the local Honda dealership this morning, they didn't even know what a rotor button was! They asked 'Is it the round thing inside the distributor'....
PostPosted: Mon Aug 20, 2012 2:34 pm
I was lucky in that the dealership mechanics were both interested in my car & very approachable - they were very helpful, but even then, I had to make a leap of faith when I ordered mine. I had the same general issue with the engine mounts I ordered, but they also fitted with no problems. Good luck! :)
 Post subject: vtec info
PostPosted: Mon Aug 20, 2012 6:30 pm
A good place to start / join for vtec info is ozhonda.
mini regards
peter d
1st victorian road registered vtec mini.
PostPosted: Mon Aug 20, 2012 7:09 pm
The C5, C6, Ax etc relates to Market ( country) and spec. Aust dealerships won't have the info for other markets necessarily. If you had a prt no they may be able to cross reference. Getting info out of Honda direct won't help either as they usually won't help. When I was a Service Manager one of the training guys was into modding and was usually good for info, though that was 15+ years ago.
Dicko.
PostPosted: Mon Aug 20, 2012 8:05 pm
In this case I am chasing the parts for my actual Type R, which I'm finding surprisingly difficult to get parts for!
I guess I'm spoilt with the plethora of parts available for Minis :lol:
PostPosted: Wed Aug 22, 2012 5:01 pm
Hi, Try here they may have the info to help. http://www.stronghonda.co.nz/
Users browsing this forum: No registered users and 41 guests
