It is currently Sun Aug 24, 2025 1:26 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 353, 354, 355, 356, 357, 358, 359 ... 568  Next
PostPosted: Sat Aug 25, 2012 5:48 pm
Picked up my eBay special motor today.
No wonder it was so cheap, it's sleazed and has spun a con rod bearing, the mains are just about cactus as well.
It's getting a good soak in my parts washer at the moment and hopefully I can unsieze it and have it ready for the machine shop this week, if they can save it then I'm gonna modify it nicely.
Was about to start on the engine in my clubby when my son came home and wanted help putting new flares on his jeep. Day over motivation gone beer 30 it is. Have to work tomorrow so the arvo might hold better for more on the clubby
If its got tits or wheels its gonna cost you
1973 Solid side Leyland Mini Panelvan 1100 in Hairy Lime(Elma)
1976 Clubby project in progress
1966 Morris Mini Deluxe in need of a full resto
1971 Mini K Garden Art
PostPosted: Sat Aug 25, 2012 6:11 pm
After many months of being in bits we now have a short engine sitting on the bench.
PostPosted: Sat Aug 25, 2012 7:22 pm
http://i691.photobucket.com/albums/vv27 ... d0db85.jpg
http://i691.photobucket.com/albums/vv27 ... 382a6f.jpg
Love the size of a mini block it fits nicely in my parts washer
PostPosted: Sat Aug 25, 2012 8:13 pm
I put a bottle of radiator flush through the engine then re-filled it with coolant. It now has the heater installed which was the last thing to go on and is running beautifully.
Just needs tyres and a wheel alignment.
How many km do I give it before I retention the head an reset the rocker gaps?
M
PostPosted: Sat Aug 25, 2012 8:49 pm
M
Once it's been run to hot, leave overnight then retighten head and do the rockers. Check again in 1000 miles or so.
You can retighten when hot but I find the nuts tend to stick, even if threads were lubed with oil or moly. Hard to get torque correct when hot.
PostPosted: Sat Aug 25, 2012 9:13 pm
Electrics, Yoda (moke) would not start, dead
Power to the solenoid, still no starting, by pass it and he starts. change solenoid, still no start.. what the..
File every connection and cleaned the earth and it fired into life.
I am amazed it just stopped starting due to corrosion.
PostPosted: Sun Aug 26, 2012 8:56 pm
Got the engine in finally, oil and coolant in, new fuel. Cranking without plugs built up to a nice 60psi first time.
Old battery is dead, need a new one, think i'll get an AGM one.
michael
PostPosted: Sun Aug 26, 2012 9:04 pm
Removed the problematic 1100S and reinstalled my old A+1275 after a degrease and pressure wash.
Seems like the weekend for engine work and installs.
PostPosted: Mon Aug 27, 2012 2:22 pm
Pulled the 168 main jets out of the Dellorto 45 and fitted 165s.
My SOTP dyno says better, so I might try 160s tomorrow.
*SOTP = seat of the pantz... :wink:
[edit] Tuesday- yep, going even harder with 160s in. :P
Last edited by drmini in aust on Tue Aug 28, 2012 1:35 pm, edited 1 time in total.
PostPosted: Mon Aug 27, 2012 5:05 pm
Dismantled both subframes
Dismantled rear trailing arms and brake setups
Cleaned and dregreased most under car components, ready to blast tomorrow and then paint!
Couldn't work out a way to get the hub nut off the front's though.. Only ever done it on a car.
Ideas anyone?
You're so square
Baby I don't care
PostPosted: Tue Aug 28, 2012 1:37 pm
Ideas anyone?
Adam, I have DrMini hub service tool #1.. you can borrow if you want or bring the hubs & shafts over here is quicker. :wink:
PostPosted: Tue Aug 28, 2012 2:27 pm
Maybe I needn't have ordered some 165 mains with that selection of idle jets then...
PostPosted: Tue Aug 28, 2012 2:40 pm
It pays to have a range of Dellorto main jets, they are pretty cheap (compared to SU needles).
for my playing about I have accumulated 2x 145-150-155-160-165-170-175-180-190.
And 170 180 and 185 air correctors. Bought in from www.dellorto.co.uk
I don't much like drilling jets out as then you dunno what they are.
Noooo I have no Weber jets at all, but they are only $5.45 ea from Melbourne.
Note I'm running the 160s for daily use, if I put it on a dyno for a shootout I would go up a few sizes.
PostPosted: Tue Aug 28, 2012 3:18 pm
Milatsmadmini
Finished building a carport for the moke over the weekend with dad, will now be out of the rain, and can work on it at night, will post a pic later!
PostPosted: Tue Aug 28, 2012 3:23 pm
Ideas anyone?
Is it a big bit of flat bar that goes over the wheel studs and you hook it into a vice?
Because this was my planned approach.
Thanks for the offer Kev, might take you up on it in coming weeks, we'll see :wink:
You're so square
Baby I don't care
