It is currently Sun Jul 27, 2025 8:13 pm
PostPosted: Sat Sep 01, 2012 5:44 pm
Greetings all.
I put a set of the blue hinge gaskets on the doors a couple years back. Had nothing but trouble. I've tightened them up a couple times. Seems the blue paper/gasket type slip.
Has anyone used something better, like rubber sheet? I was thinking maybe a squirt of Sikafex (as well) to help lock them into place.
I don't want to "cave the door in" tightening them again and again.
Alex.
PostPosted: Sun Sep 02, 2012 11:20 am
Hi Alex
You could try hard plastic from an old oil container or ice cream container or similar , select the colour you like.
I havent tried this but i intend to. I believe other people have used this.
The beauty of it is it doesnt compress and deteriorate like your other gaskets do. Hope this helps
Regards
PostPosted: Sun Sep 02, 2012 9:39 pm
Thanks Guna...
I'll look around for something with a little grip. I was thinking a trip to Clarks Rubber for something UV stable and strong. The paper ones just slip and drives me nuts.
Thought for sure others may have dealt with this?
Alex.
PostPosted: Sun Sep 02, 2012 9:47 pm
I'd use icecream tub plastic, as suggested.
Watch it using rubber now, 90% of it comes in from China and is absolute rubbish. UV stable rubber? Not most rubber these days.
Example- 2 years ago I fitted nice new oval rubber gaskets to my windup door handles. Bought them here too. Car hardly ever gets parked outside.
I don't know why I bothered, the rubbers both sides have shrunk in under the escutcheons already.
I will be refitting some s/h old originals, they are still the right size after 40+ years.
PostPosted: Sun Sep 02, 2012 9:54 pm
Have you got the correct series of washers and wedged spacers behind the door skin or just a nut and washer?
This could be affecting door sag.
Now with 2 extra ports!
PostPosted: Tue Sep 04, 2012 10:20 pm
Thanks All.
I'll give it a go on the weekend (plastic)
I think I have the original nuts and washers etc. I seem to remember the curved washers on the front of the hinges. I'll have to pull the trim off to see what I used on the back (inside thread)
Cheers Alex.
PostPosted: Wed Sep 05, 2012 10:19 pm
You can get gasket material from repco. Is pinkish in colour and is almost identical to the original gasket material. Has a small amount of crush in it and holds well a bit like a spring washer would. Take your time cutting it out and punch the holes out with a hole punch.
G.
1962 Mini Speed sports sedan
PostPosted: Thu Sep 06, 2012 9:15 pm
Thanks "G"
I'll have a look at this too.
Alex.
Users browsing this forum: Phil 850 and 79 guests
