It is currently Sat Aug 02, 2025 9:53 pm
 Post subject: source of engines
PostPosted: Fri Sep 07, 2012 1:51 am
Hi all.
The clubman I bought recently has a 998 that is a bit tired, and the gearbox is a bit ordinary, particularly second gear.
The plan for this car is to use it to teach my daughter to drive then, when she has her own car, embark on a engine conversion and body restoration.
I'd like to fix the gearbox and use a freshened engine without going silly. The thought process at the moment is leaning toward finding a 1275 and gearbox that need work, repairing/rebuilding them, then dropping them in so the car is only off the road for a short time, and I have the advantage of the little bit of extra oomph that a 1275 will provide.
Can anyone steer me in the direction of a source of second hand engines and gearboxes that may yield what I am looking for?
 Post subject: 1275
PostPosted: Fri Sep 07, 2012 5:45 am
!275 engines are getting hard to find and not cheap to buy any more.
"Let us remove your "SHORTS"
PostPosted: Fri Sep 07, 2012 6:44 am
Josh @ minimports
PostPosted: Fri Sep 07, 2012 7:07 am
Mods rock!
http://www.ausmini.com/forums/viewtopic.php?t=77785
PostPosted: Fri Sep 07, 2012 7:32 am
nothing wrong with a good 1100 mildly tweeked
makes a good road engine
but if you want to go racing and have lots of mony to spare :)
65 panel van Sprog
73 panel van Iggy
PostPosted: Fri Sep 07, 2012 11:11 am
Josh @ Mini Imports
0419396877
give him a bell, if he doesnt answer, leave him a msg as he is busy!
-Cam
IS NOW BACK ONLINE AFTER SOMETIME..... SORRY TO ALL, FOR NOT REPLYING TO PM'S!!
PostPosted: Fri Sep 07, 2012 11:14 am
TheMiniMan wrote:
Josh @ minimports
MiNi MuLiShA wrote:
Josh @ Mini Imports
Can anyone hear an echo :?: :D :wink:
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Fri Sep 07, 2012 11:36 am
MiNi MuLiShA wrote:
Josh @ Mini Imports
0419396877
-Cam
Mine was more detailed with all the info needed, hence my post :lol:
PostPosted: Fri Sep 07, 2012 11:39 am
Take into consideration that if you fit a 1275 into any mini then disc brakes are a legal requirement.
Without getting into a circular argument that says "my drum brakes are perfect" the drums are only just adequate and the extra "oomph" from a 1275 makes the car rather under braked especially for an inexperienced driver.
You also have to change the rear wheel cylinders to suit the disc brakes but that is a relatively inexpensive and easy job to do.
Mike
PostPosted: Fri Sep 07, 2012 11:53 am
I also recommend Josh at mini imports, why bother trying to find a 30+ year old small bore when you can get a more recent 1275 and all the goodies.
Yes disk brakes are a legal requirement.
Contrary to popular belief drum brakes will in fact stop you better than disks as they have heaps more surface area and as they turn they "lock on" so you are not limited by hydraulics.
HOWEVER they will only do this once, so its purely academic and they need constant adjustment so disks win out.
PostPosted: Fri Sep 07, 2012 12:21 pm
Question about the brakes, does anyone know if u require the 8.4" disc brakes or can you use the 7.5" ones that fit under 10" rims? I'm doing the same thing soon but would like to keep 10" rims
PostPosted: Fri Sep 07, 2012 12:31 pm
7.5 S discs are fine.. no need for 8.4s unless running dirty big wheels.
Some here may tell you you need a servo, but they work fine without (using EBC blackstuff or greenstuff pads).
[edit] But stay away from 7" Cooper 997 or 998 discs, they are too thin and the 997 pads are postage stamps. Good for Cooper period correctness only.
PostPosted: Fri Sep 07, 2012 12:45 pm
And if using a rover import you cant go down in size without engineering approval.
PostPosted: Fri Sep 07, 2012 12:49 pm
Is this legislated somewhere, or is it the same theory that says just because a Cooper S ran a servo, everybody must (with 7.5 discs)?
PostPosted: Fri Sep 07, 2012 1:21 pm
Mike
The brakes will be the first port of call, regardless of power plant. I'm trying to find information on the bumpsteer characteristics, and if there is a known fix, when using 12" wheels. If there is, then I will go to the metro turbo brakes. The plan is to make this a solid all round performer in the future, with brakes and handling being at the top of the list.
