It is currently Tue Aug 12, 2025 4:50 am
Post new topic Reply to topic  [ 48 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sat Sep 22, 2012 3:07 pm
http://www.ebay.com.au/itm/NEW-Innovate ... 3363wt_908
A bit cheaper from USA, but that's further to send and complain to if I have a warranty problem.
PostPosted: Thu Sep 27, 2012 2:19 pm
MTX-L A/F gauge kit arrived yesterday. I just need to fab up a sensor clamp/mount for the tailpipe, extend the power cables to reach the battery and it should be a goer next week. :P
 Post subject: tailpipe clamp
PostPosted: Thu Sep 27, 2012 4:02 pm
Hi Doc
i have the innovate tailpipe clamp and i would recommend sticking the tube ( the part that catches the exhaust gas further up than on the bought one)
For 'fabrication' the innovate tube is 14cm long on top and rolls round and under - to flow past the sensor and then back ) it is 1cm diameter
i have a single pipe that exits via twin upswept pipes and my tailpipe readings were affected by this - only the idle - when it wasn't pushing much exhaust gas. I put a bung in a no such problems. It may not be a problem on single pipe , but it may be worth sticking it further up.
cheers FNQ
PostPosted: Thu Sep 27, 2012 4:06 pm
I copied mine from the one GR uses.
It is a straight 8" long bit of 3/4" bore pipe, the sensor spud is welded on 3" from the aft end.
So there is ~5" of sensor pipe up inside the tailpipe.
PostPosted: Mon Oct 01, 2012 2:52 pm
All assembled now as a portable, is in car, will go for a test drive tomorrow.
I used an M18x1.5 nut for the sensor's mount, and kept the spud they supplied in case I want to weld that into the LCB's Y-piece as a permanent install.
8ft interconnection cable to sensor not shown.
PostPosted: Mon Oct 01, 2012 5:27 pm
Milatsmadmini
Great work Kev! May have to come around and borrow that soon... 8)
PostPosted: Tue Oct 02, 2012 4:34 pm
It's alive!!
Mounted in end of the tailpipe it doesn't work at idle, due to the cam it has in- it just reads 22.4 due to all the air going to and for.
Meter works great once off idle though- running around in traffic it seems a little rich (11.5-12.0) cruising at light throttle openings, but once up to 1/4 throttle and above it's sitting around 13.0-13.5. I've not had it past 4000 rpm yet though.
I will try slightly leaner idle jets, but really, it's closer to correct than I thought it would be, considering how I tuned it.
I'll do a couple of freeway on-ramps tomorrow and see if the top end leans out.. or not. :P
PostPosted: Tue Oct 02, 2012 4:46 pm
Good work Kevin,
I have the innovate item like GR's (LM1) and its pretty good, i used a bigger size pipe to catch more exhaust gas.
light throttle mine is at low to mid 20's and as soon as i go above that it drops to 15-16 and on hard acceleration on 15 to 18 pound boost i am at 12.5 to 13.5, so i am pretty happy with it.
would be interesting to do a back to back test on both units.
Grant
100% Pure A Series Turbo
PostPosted: Wed Oct 03, 2012 6:09 am
It's alive!!
Back from holiday and straight back into it I see :wink:
Presumably if the unit was mounted at the extractors/collector, you would get a good reading at idle as well, as no fresh air would be reaching it?
PostPosted: Wed Oct 03, 2012 8:45 am
Yes, it would work at idle if sensor was mounted in the headers, however I wanted it portable so I can check both my cars, and also help other people.
I'm not installing it permanently- because I'd say once the jetting is set up, the gauge would be about as useful in the dash as having a vacuum gauge..
PostPosted: Wed Oct 03, 2012 11:55 am
OK after fiddling with jetting I've settled on 54 idle jets, 155 mains and 180 air correctors.
It cruises along at around 16.0-17.0:1, goes to about 13.0:1 at full throttle and it's not leaning out the top end.
Chokes are still 36mm.
PostPosted: Wed Oct 03, 2012 4:22 pm
Did you change the idle jet holders?
PostPosted: Wed Oct 03, 2012 4:49 pm
Nope.
I didn't change the emulsion tubes either, they are still the .6 ones.
BTW I emailed you before that my old idle jets were 50, but they were actually 55.
It is noticeably leaner now with the 54s in. I had to open up the idle mixture screws 3/4 turn.
I'll go see GR tomorrow and check the 55s were not in fact drilled out bigger..
PostPosted: Thu Oct 04, 2012 1:00 pm
After driving it a bit more, the 54 idle jets are just slightly too small- it idles OK, but has a flat spot just above idle. So, the `55's are back in.
[edit] these 55s turned out to be 58s, someone drilled em before I got the carb.
So I had GR drill the 54s out to 55 (0.55mm) today.
[edit 2]
155s (actual size) are working fine, idles OK and no flat spots off idle- compared to them the 154s were way lean and the (actual size) 158s obviously too rich.
I'll buy a pair of 156s to try also, but the 155s can stay in for now.
I am amazed that a 0.01mm size change in an idle jet has so much effect on the mixture over such a large throttle range...
PostPosted: Thu Oct 18, 2012 3:13 pm
Well I took it for a run up to Pie in the Sky yesterday. Since I checked the Dellorto's A/F ratio and rejetted it, it is going like the proverbial sh!te off a shovel.
It has never gone so hard, and it is using less fuel too. 8)
Users browsing this forum: No registered users and 226 guests
