It is currently Wed Aug 06, 2025 9:07 am
PostPosted: Tue Oct 16, 2012 8:01 am
If the washer face looks that bad, replace the nut too. It ain't flat anymore. :cry:
PostPosted: Tue Oct 16, 2012 8:05 am
Yeah. It was on the shopping list.
PostPosted: Tue Oct 16, 2012 8:44 am
I suspect I know the answer to this one.
PostPosted: Tue Oct 16, 2012 9:49 am
The Mini King
It is a bit hard to tell in the photo, But It may be ok, have a look at the splines at the rear if they look about the same at the front it will Be Fine if however they taper down towards front Then Get a new one,
What do You Think Kev
PostPosted: Tue Oct 16, 2012 10:33 am
If the new drive flange rocks around on the CV splines, or you see flats on the end of the CV's plain centre section, you'll need a new CV too.
PostPosted: Tue Oct 16, 2012 7:29 pm
I wonder when I get to stop replacing?
Pot joints?
Diff?
PostPosted: Tue Oct 16, 2012 7:31 pm
Pot joints?
Diff?
Diff
Layshaft
Primary gears
Crank Bearings
Re-bore
1/4" stroke
Turbo
PostPosted: Tue Oct 16, 2012 7:33 pm
Never
It's a mini :D
PostPosted: Tue Oct 16, 2012 9:16 pm
PostPosted: Tue Oct 16, 2012 9:46 pm
Get a new CV and bearing kit, make a job of it. Do it once, do it right. :wink:
PostPosted: Tue Oct 16, 2012 10:31 pm
That's completely not my style.. :)
